update 0.7
01/06/2021 at 10:06 • 0 commentsIn the last version (called 0.7) I cleaned up a little bit the code, removed the redundant "message builder", and added "clean button".
also disabled file creation on start up - now new file is generated on starting the log.
New release 0.5
10/12/2020 at 16:53 • 0 commentsUsing the word 'release' for such a project is a bit overkill, but in the absence of a better term...
so, the performance of the chart object of .net is not really adapted for heavy applications, however, if one disables it (like no interaction with system whatsoever), the redraw capabilities jump up drastically.
in the version 0.5 I also added some basic variable names recognition.
Evgeny
