GPRino
Ground Penetrating Radar using Arduino
This project developed a very low cost (under 300 USD components cost) Ground Penetrating Radar. The acquired data can be visualized onboard, in real time, as well as stored and transferred to a PC for further processing.
The digital section uses an Arduino Mega 2560 board.
The onboard visualization uses an LCD shield for Arduino Mega 2560.
The analog section is custom built.
The frequency range is 323 MHz - 910 MHz.
The construction and software files contain the complete information for building the project.
Software_v6.zip
Arduino and PC (in LabVIEW 2013) software source code
x-zip-compressed - 80.47 kB - 05/18/2024 at 19:11
Download
Operation_Instructions.txt
Operation instructions
plain - 2.09 kB - 05/11/2024 at 10:26
Download
Antennas_v2.zip
Antennas - New version of antennas, must be printed on double-sided PCB FR4 laminate size A4 (210 x 297 mm). PDF for Toner Transfer construction (Top layer mirrored) and GERBER files
x-zip-compressed - 70.87 kB - 05/15/2024 at 11:54
Download
PCB_Construction_Toner-Transfer-Method.zip
PCB images in PDF for Toner Transfer PCB construction (Top layer mirrored), and schematics
x-zip-compressed - 1.85 MB - 11/03/2024 at 11:15
Download
LF(GPR_LF).zip
OrCAD 9.2 design files and Gerber for Low Frequency board
x-zip-compressed - 115.54 kB - 11/03/2024 at 11:16
Download
View all 9 files
  • 1 × Arduino Mega 2560
  • 1 × LCD TFT 3.2 inch + slot SD card shield for Arduino Mega LCD TFT 3.2 inch 480 x 320 Pixels + slot SD card, using HX8357 chip
  • 1 × JTOS-850VW+ VCO
  • 1 × PAT-10+ RF Attenuator
  • 2 × PSA4-5043+ LNA
View all 49 components
  • 19.10.2020
    Mirel Paun10/19/2020 at 14:14 0 comments
    System tested on a bridge. This is the GPR image obtained for the bridge in the photo:
  • 08.10.2020
    Mirel Paun10/08/2020 at 16:03 0 comments
    System tested and works fine.
    Antenna coupling is quite high. Would be nice placing the antennas at a bigger distance from each other, or using more directive antennas in order to reduce unwanted coupling.
View all 2 project logs
  • 1
    Board stack.
  • 2
    Board stack in box
    This is how the electronic boards are stacked.
  • 3
    RF (GPR_RF) board top.
View all 9 instructions
Signa wrote 12/10/2022 at 10:19 point
Ciao Mirel, great project!!! I am  trying the setup, but before spending on  double side PCB i am simulating antipodal Vivaldi antennas radiation pattern. In that sense, even if shape is clear from file,  would be great to have some clarification on antenna geometry, specifically on its dimension. Also it is not very clear from the gallery if PCB used is flexible and the antennas best position. Can you please help us somehow with more detailed picture/scheme or something else?
Thank you a lot and again, my compliment for the incredible project !!
nouh wrote 12/12/2022 at 01:40 point
hello .
making antipodal vivaldi antenna for this project
https://www.youtube.com/watch?v=hus-xqW976A&ab_channel=Noahskills
Signa wrote 12/14/2022 at 09:26 point
great video Nouh, if i can ask to you, what are dimension of double sized PCB you used? 15cm x 25cm...
recompiller wrote 02/12/2024 at 20:30 point
your link is not alive, renew plz
nouh wrote 12/16/2022 at 23:37 point
20/30
Piyaldasanayaka1118 wrote 12/03/2022 at 05:49 point
Sir, how do you make a 3d that tries to take care of things under the ground.  Please make something like that.  It is very valuable.. diagrams and.  Will you make a video showing all the equipment... we hope.  For example, secret imager 3d, (uxo mini underground imaging detector), easy way detector, produced by Adrenaline Company, can be named...they are umbrellas.  Easy to use.  How to make such a device.. Do the project and show it.  Good luck to you, happy for you.
mshahvali2369 wrote 08/01/2022 at 21:29 point
new verjen gpr  who is make new ediyt shomatic or circuit ican not find ic stjtos850vw
Piyaldasanayaka1118 wrote 12/03/2022 at 06:19 point
LKR 16,382.49  10%OFF | Free shipping  JTOS-850VW BK377 400-850MHz
https://a.aliexpress.com/_mrmYus4
mshahvali2369 wrote 08/01/2022 at 21:25 point
Are you can help me cod and pdf gpr send for me
adelangel wrote 06/17/2022 at 03:51 point
can anyone tell me they created this in the states
Thanks
sultanbaybars wrote 05/18/2022 at 16:31 point
can you please add a gerber file for pcb printing
sultanbaybars wrote 05/18/2022 at 16:29 point
CAN YOU PLEASE ADD A GERBER FILE
Duane C. Johnson wrote 04/12/2022 at 22:27 point
Hi Mike;
Just a thought:
Do you think most of the RF and display functions could be performed using the very cool "tinySA" spectrum analyzer, (about $70 us)?
It has a built in RF output port that can track, with or without offset, from the input port. It can be controlled through a USB cable and display on a PC.
redrok
redrok@redrok.com
uglychicken2005 wrote 02/17/2022 at 01:20 point
Projet.frogdv,
Have you completed all your modifications as of yet? I would like to see all your alternative approaches on this project. Especially involving some of the hard to find components, antennas and the LCD . It's all quite intriguing! Maybe link a new project page in order to keep some of the cross confusion down if possible.
5.9188 wrote 01/28/2022 at 05:57 point
Anyone here ?on line? Dear
5.9188 wrote 01/28/2022 at 05:55 point
I like very much , I have some Q, 1, from the picture of scan bridge ,which is the water?
2,  what the antenna size ,and how to contact the board?
sorry for my poor english
spidersenses wrote 11/18/2021 at 11:09 point
I am an amateur and I find your project really interesting. I have a dumb question. I don't understand the role of LF, RF board. Can you please explain?
[deleted]
Krzysztof wrote 11/17/2021 at 13:29 point
You program Arduino with the Arduino IDE. Sampling is limited to SCL = 400kHz. For safe frequency stabilization in the JTOS-850VW, it would be necessary to add in line No. 400 'delayMicroseconds(1);'. Although this will increase the sampling period to 500 us, it will not change anything in the work system. A *.dat file is just raw data on an SD card for use in any other graphics program that supports GPR, it can be read in a text editor or Exel.
krayberk55 wrote 08/19/2021 at 15:40 point
With which program can I open the vi file?
Mirel Paun wrote 08/21/2021 at 08:55 point
LabVIEW 2013.
5.9188 wrote 01/28/2022 at 05:58 point
Dear Mirel paun  Are you online ?
projet.frogdv wrote 07/14/2021 at 09:13 point
Hello
Regarding the screen I have located this video https://www.youtube.com/watch?v=ihbLaOd3x8I
that a 7 inch screen LCD DMT80480T070_03WT. with SD memory slot , price is in the 100USD which is reasonable .
Do you think / can you confirm that a possible solution even wth some software mods
Regards
projet.frogdv wrote 07/11/2021 at 17:14 point
Hello , thanks for sharing your work I have check as I have make already somme works on VCO , It seems your control your VCO by using the pin 5 which is a normal way but your OPAMP OP1077 is powered in 12V from your LT3421 only so your output voltage cannot be over 12V but to reach 900 MHz you need 18V to reach 794 MHz with your VCO at 12V you are at 793 MHz ( 25 deg C ) . That just a question as your design is clever and afordable I plan to redesign the PCB to use a more common CVCO55BE-0400-0800 and cheaper VCO , another point to help is to feed the VCO and the OPAMP with low noise voltage , check http://www.cqham.ru/projects/voltage_regulator_noise/finesse_20voltage_20regulator_20noise.htm  . I will post my PCB modification and results , thanks again for your work .
Mirel Paun wrote 07/11/2021 at 20:03 point
Hello! The LT1077 OpAmp is powered from the LT3461 output voltage, which is 1.255 * (1 + R10/R11) = 23.84V.
projet.frogdv wrote 07/12/2021 at 16:40 point
Hello , Great thanks for clarification regarding the LT3421  , I am in process to modify the PCB to use the CVCO55 (CVCO55CW-0400-0800 which run from 0V to 12V and can cover 390 MHz to 929 MHz just before max voltage 12V and cost 22 Euro from Mouser ) powered also in 5V as now china import are heavily taxed in EC and starting price your original VCO is over 50 USD per unit ,  . I plan to use 24 DC lithium battery ( available electrical bike  battery ) so I need to design an additional  PSU board I try to avoid to redesign too much in the aim to reach quick as possible a working system by using available already designed circuits.
Question : have you tested the maximum deepness you can reach with your setup
I have a CAD design for a 250 to 950 MHz Vivaldi antenna on 1.6 mm FR4 I will post it , this antanna have been test ( S11 value ) , out side dims are similar to your antenna
Regards
eltonshalin wrote 08/17/2021 at 05:26 point
The link you have provided is not working can you share it again here or in my email id: eltonshalin@gmail.com
iain.price2 wrote 05/24/2021 at 19:55 point
Hi, earlier uglychicken wrote: “Could the CVCO55CW-0400-0800 be used in place of the JTOS-850VW+??” I too am finding it difficult to source and JTOS and am not sure of a suitable alternative.... anyone using something different or know of a source I can order from? I am working on modifying the code to work with different LCDs, I will post in a week or so when I have things working.....
lampart wrote 05/26/2021 at 18:57 point
Aliexpress
ahmedasaad wrote 04/27/2021 at 20:41 point
Thank you, sir, for your response and attention
But is it possible to download some pictures of antennas from inside the plastic box.
ahmedasaad wrote 04/23/2021 at 12:38 point
Thanks Mirel. Also would it be possible to upload some photos of your existing antennas inside the box plastic ? Especially where the TX and RX feeds are connected.
egyfalcon73 wrote 05/17/2021 at 00:42 point
التوصيلات موجوده في الرسم
ahmedasaad wrote 04/16/2021 at 13:33 point
 GPRino is very good - please help send me pictures of electronic boards from top and bottom.
ahmedasaadmourad16@gmail.com
egyfalcon73 wrote 05/17/2021 at 00:43 point
التصميم كله موجود اوركاد
5.9188 wrote 01/28/2022 at 05:59 point
Please send me  5.9188@163.com   Thanks
