1Board stack.
2Board stack in box
This is how the electronic boards are stacked.
3RF (GPR_RF) board top.
4RF (GPR_RF) board bottom.
5LF (GPR_LF) board top. The variable resistor has been replaced with a fixed one in the final version.
6LF (GPR_LF) board bottom.
7The wheel switch.
This is how the wheel operated scan switch works. Only one cam was presented for simplicity. You need 2 cams on the axle, equally spaced.
8GPR working.
9GPR data can be transferred to PC. This is an older software version, the new one adds more functionality.
AMIGO ESTE APLICATIVO PARA O PC COMO ABRIR ELE ?
OLA AMIGO ESTOU TRABALHANDO NESTE PROJETO GPR ACHEI INTERESANTE
