Dissecting a hand-held NOAC console (Sup 400-in-1)
This is an attempt to understand how these little things work, and what we can do on it.
Public Chat
This is an attempt to dissect and to understand how these little handheld NOAC (Nintendo-on-chip) consoles that are being sold for around $5 in the market.
You can read more about the NOAC on the Wikipedia page: https://en.wikipedia.org/wiki/Nintendo_Entertainment_System_hardware_clone
We know that this thing in the black epoxy has the clone of the Nintendo Entertainment System. Upon further reading, there's more to being the clone too - possibly an enhanced version like the VT-series (http://www.vrt.com.tw/datasheet.htm).
What's inside it? How does it work? Could I load its ROM another new code? That's the question!
chicago_oblique_basic.chr
Sample CHR font for Hello World app in the log.
chr - 4.00 kB - 06/23/2024 at 03:16
Download
TFT lines on the board.
Bitmap Image File - 6.32 MB - 10/11/2020 at 12:53
Preview
ST7789 16-bit 8080-II interface datasheet.
Portable Network Graphics (PNG) - 513.85 kB - 10/11/2020 at 12:35
Preview
COB Flash and NOAC on board with the TFT removed.
JPEG Image - 1.27 MB - 10/11/2020 at 12:33
Preview
  • 1 × Logic analyzer Recommended a Digital Discovery or Analog Discovery 2
  • New Menu Builder, and Trouble with the TSOP-56s!
    YH-workshop7 hours ago 0 comments
    Hi! Finally I got to revisit it again after checking the disassembly of the software in this github.
    The problem with it is, right now it is very difficult to compile and load the games because:
    • manually place the game graphics and code
    • set the OneBus registers
    • and recompile.
    No, the Nesmaker from NesDev doesn't work - the init code does not match whatever hardware that is on the handhelds. I have read this over and over again to be sure, and I'm open to new feedback for this one! :D
    I have written this builder to facilitate the task of loading Mapper 0 and 4 games and then compile it with the initialization ROM (again, you need to get the ROM dump from the handheld, and the build folder from the custom menu template!):
    This compiles the whole thing into the BIN file for the emulator, and also a separate BIN file for the handheld. There are variations on these handheld such as bit swaps so after all the compilation it reverses whatever it is to be workable for the unit.
    However, the recent one I'm testing are the TSOP-56 variant - the ones with the S29GL flash. It looks... easy right, since I can undo it through the hot air...?
    Not really! Yes, with enough experience, I could do it a few times, but repeated cycles of unsoldering, reflashing and soldering could make these flimsy traces snap very easily! I have messed up one board because of this!
    Worse of all, do not use a vice to hold the PCB of that unit too tightly! Flexing the board would means it breaks immediately!
    Imitating previous work of mine, I might be doing a TSOP-56 version for this one so the board doesn't have to tolerate too many of the repeated cycles of de/soldering. :D
  • More testings on different NES games!
    YH-workshop09/21/2024 at 06:53 0 comments
    From the previous log it is mentioned that only Mapper 0 and 4 games can be put into these consoles.
    However, some of the games in the 400-in-1 console contains Mapper 4 that are converted from Mapper 2 such as Jackal. Those games are running without CHR-ROM and only CHR-RAM instead.
    Earlier on, when such games are inserted into the console with the custom menu, it gives a black screen, or garbage output.
    Then, checking how did the game selection in 400-in-1's original menu works, it is noticed that there is a specific sequence, and a specific range of number that gives these converted games a correct tile output.
    I have rearranged the loading of these OneBus registers ($401x) following the ones in that original menu:
    jumpToProgramInRAM:
        lda _zR410A
        sta $410A
        lda _zR410B
        sta $410B
        lda _zR4100
        sta $4100
        lda _zR4105
        sta $4105
        lda _zR4106
        sta $4106
        lda _zR4107
        sta $4107
        lda _zR4108
        sta $4108
        lda _zR4109
        sta $4109
     Since these games does not run on CHR-ROM, the configuration of the OneBus registers at $201x are not involved. However, the bottom nibble of the $4100 must be between 0x04 and 0x0F for these games to work I'm not entirely sure why, and it works on both the emulator, and on the handheld itself.
    Well, here it is - at least it loaded correctly! :D
    Note: I have tested other Mapper 0 games with only CHR-RAM. It doesn't work at all on both the EmuVT and the handheld too.
  • Custom games in action!
    YH-workshop08/31/2024 at 09:05 0 comments
    That was the question back in 2020 - well, to answer this time, yes it works! However it need effort to understand the OneBus, then the ROM dumping process, and finally to recompile the menu with the part of the dumped ROM code that initialises the TFT.
    The video: some experimentation with MMC3-mapper games here - it works normally on the handheld. Currently Mapper 0 and MMC3 games worked well. If not mistaken, the ones with MMC1 requires modification of the code (to be compatible to MMC3) which is not covered in this research.
    As usual - I'm still in the process of compiling instructions on how to build the custom menu, and also to find a way to build a more economical flasher + dumper so you do not need to use the T56 programmer! :D
  • Update and a git website added!
    YH-workshop08/23/2024 at 14:06 0 comments
    These handhelds can be actually programmed with another game, by further testings, provided if you get the registers (especially the $41xx OneBus-related) correct.
    However, you need to dump its original ROM and try to work around its bit-swaps and the TFT initialization routines.
    As writing the ROM dump analysis and the such is a bit too difficult inside the log entry, I have separately written a Github page on this one: https://nyh-workshop.github.io/Custom-ROM-Sup-Game-Box-400in1/
  • Loaded a "Hello World" app inside!
    YH-workshop06/23/2024 at 03:11 0 comments
    Okay, so I managed to examine the dump some more and trying to strip the startup code to its bare minimum.
    However, on this particular newer dump, the code is significantly more complex than the previous one, due to the TFT init routines (that covers many other models apart from the GC9306), and also many other unknown registers such as 0x413x are being accessed.
    Instead of stripping it first to see if it works or not, I grabbed the whole first 512K (0x80000) of the code and pasted into another empty bin file.
    The startup code is just too much work to strip at the start so I filled the majority of the menu code from 0x6E000-0x6EFFFF with zeros and replaced it with another jump to another area away from that first 512K - to 0x82000
    ; org 0x6E000:
    cpyToRAM_Loop LDA $E800,X
                  STA $0400,X
                  DEX
                  BPL cpyToRAM_Loop
                  JMP $0400
    ; org 0x6E800:
              LDA #$00
              STA $4100
              LDA #$05
              STA $4107
              LDA #$01
              STA $4108
              LDA #$02
     Converting this back to 6502 machine code and paste it, it should look like this:
    These NOAC's bankswitching methods have to be copied into the RAM area and run it for it to work. Else, it won't go to the new address.
    Of course, I tested this in the EmuVT 1.36 to see if it jumps to the address. When it does, I actually proceeded into writing more code at the 0x82000 onwards.
    Note: The backlight seemed to be only switched on after the TFT init routine!
    Compile this in ASM6F and paste the code into the section 0x82000:
    helloText EQU $A200
    ; main program here:
    .org $A000
    main_app:
        ; diasble interrupts on APU:
        lda #$40
        sta $4017
        lda #$00
        sta $4010
    vblankwait1:
        ; First wait for vblank to make sure PPU is ready
        bit $2002
        bpl vblankwait1
    enableBacklight:
        lda #$1f
        sta $413f
        lda #$0b
        sta $4138
        lda #$0f
        sta $4139
        ; clear RAM:
        tax
    Init_ClearRAM:
        sta $000,x
        sta $100,x
        sta $200,x
        sta $300,x
        sta $400,x
        sta $500,x
        sta $600,x
        sta $700,x
        inx
        bne Init_ClearRAM
    Init_PPU_chr:
        lda #$00
        sta $2012
        lda #$00
        sta $2013
        lda #$00
        sta $2014
        lda #$00
        sta $2015
        lda #$00
        sta $2016
        lda #$00
        sta $2017
        lda #$20
        sta $2018
        lda #%00000000
        sta $201A
        ; fill background with one value for 8 tiles:
        lda $2002
        lda #$20
        sta $2006
        lda #$00
        sta $2006
        ldy #$00
    FillAllBackground:
    FillBackground:
       lda #$00
       sta $2007
       inx
       cpx #$ff
       bne FillBackground
       iny
       cpy #$04
       bne FillAllBackground
        ; Fill palette with 0x0f, 0x30, 0x30, 0x30:
        ; $3f00 = 0x0f
    FillPalette:
        lda $2002
        lda #$3f
        sta $2006
        lda #$00
        sta $2006
        ldx #$00
    FillPalleteLoop:
        lda #$0e
        sta $2007
        lda #$0e
        sta $2007
        lda #$2a
        sta $2007
        lda #$0e
        sta $2007
        inx
        cpx #$04
        bne FillPalleteLoop
    PrintText:
        lda $2002
        lda #$20
        sta $2006
        lda #$00
        sta $2006
        ldx #$00
    Print0:
        lda helloText, x
        cmp #$00
        beq PrintDone
        sbc #$20
        sta $2007
        inx
        jmp Print0
    PrintDone:
    Init_PPU:
        lda #%10000000
        sta $2000
        lda #%00001010
        sta $2001
        lda #$0
        sta $2005
        sta $2005
    here:
        jmp here
    NMI:
        rti
    .org helloText
        .db "HELLO WORLD!", #$00
    Wait - you need to put the CHR into the area 0x80000 too. Sample CHR file provided - get the "chicago_oblique_basic.chr". I got the sample CHR from the NesDev forums, and paste it at the 0x80000 area. It should look like this:
    After all is done, program this bin into the NOR flash using the T56 programmer (or any other equivalent). You should be seeing this one:
  • Dump dissected - and new issues with the Teensy 4.1!
    YH-workshop06/23/2024 at 02:20 0 comments
    Whew! I have a bit of breathing space this weekend so I went to look into the new dump from the earlier logs.
    The strange part is, this particular dump from the later Sup 400-in-1 models are always different than the year before. This model "CFJSUP Ver 2.0 2023.5.18" still have the same old menu from the previous ones, but the startup codes are different.
    To summarize it, this one does:
    1. Jumps to addresses next to each other for a few times.
    2. Then branches into an area where the opcodes have swapped bits 4-5.
    3. It goes into a startup - and the TFT init routines are more complex this time: it actually includes many other models inside for convenience. There are a list of the TFT models in the area around 0x2B000:
    Highlighted one is a GC9306, which the handheld is having right now, and being selected too.
    4. After all is done, it goes into address 0x6E000, where the game menu is in. Else, it goes to 0x6A000 where the "Aaronix" test app is there if you hold B and Y during reset.
    On other story, my Teensy 4.1 flash emulator doesn't work all the time! When this is connected to the mentioned console, it does not work anymore. Even with the new PCB design I made too. It kept disconnecting and it becomes unresponsive. I guessed overclocking the Teensy 4.1 has its limits, even with the heatsink and the fan blowing on top of it! Guess that I need to use an actual NOR flash for this one! (Note: Use a 2.54 female header on the Teensy 4.1 slot! Do not solder this Teensy 4.1 directly onto it!)
    (This PCB does the same thing from this log, but more neat and I can use the headers. These headers are connected to the nor flash breakout board on the handheld console)
    But luckily, I also designed the NOR flash adapter in case things doesn't go right with the Teensy 4.1 solution, or I needed to test if a TSOP-48/56 NOR flash (with the RT-TSOP48 adapter) works on this console (same thing here - make sure you use 2.54 female header on that RT-TSOP48 slot!):
    Plugging it in and cannibalizing the flash (S29GL064) from another one of the cheap consoles, load it up with the same dump through the T56 programmer, I managed to get the dump to run on the flash (but with only 8 megabytes!)
    Is there any chance for it to load a custom app even without using the Teensy 4.1 NOR flash emulator??
  • Opcodes has its bits swapped??
    YH-workshop04/11/2024 at 03:51 0 comments
    After from the previous log, I took a look in the EmuVT's debugger and noticed that there are many jumps to a nearby locations and "strange" opcodes that don't make any sense:
    Hmm... looks like some of the stores especially at the $412D could make sense, since these stuff often use the registers around that address. And the jumps too. Look at the end with the "F5FE" - looks like a jump to the main startup code?
    Wait... I recalled about chatting about those VT-02 OneBus systems at NesDev Discord, and also these NesDev article: https://www.nesdev.org/wiki/NES_2.0_Mapper_256, and another BGC article: http://bootleg.games/BGC_Forum/index.php?topic=2412.0
    Something reminded me that there could be swapped bits somewhere in the opcodes. After checking these instructions on a pen and paper, bits 4 and 5 at the opcodes are actually swapped!
    After swapping these bits manually in HxD and pasted this modified code back, it runs on the EmuVT now!
    These newer Sup 400-in-1 handhelds are having these strange bit-swaps at the addresses, and this one having a bit-swap at its opcodes before the startup happens!
  • Another new romdumper - this time it's faster!
    YH-workshop04/11/2024 at 03:32 0 comments
    When trying to dump a newer Sup 400-in-1 ROM on my Raspberry Pi based dumper, the thing doesn't load well in the emulator. There are many corruptions in the ROM when viewed through the YY-CHR app. The little dots at the empty area are those corruptions:
    Plus, this thing takes a whole day to dump and it's really slow, and I have a better idea to port this whole thing to a Raspberry Pico instead. After figuring out the newer problems such as the MCP23017s couldn't be detected and these corruptions, I had modifications to the circuit:
    This time, it dumps really fast and about 35 mins later I get the 16 megabytes ROM dump. You can check this ROM dumper here too if you want a faster alternative!
    However, when trying to run it in the EmuVT - it just gives me a black screen and it doesn't work! What gives?
  • Dissecting the startup!
    YH-workshop03/31/2024 at 03:41 0 comments
    As mentioned in the previous logs, if you have used this method, you may able to get the dump and run this binary in the EmuVT emulator.
    So on about last year, I actually dissected the flow of the program and written it into a piece of paper. This analysis does not include how the game menu works and the test screen - only the startup.
    Using the EmuVT emulator and putting breakpoints one by one, I managed to see things like:
    • Getting the starting address at $7FFFC.
    • Initializing registers at $412B and $412C.
    • Dumping about 15 values into the $4200.
    • It went on jumping back and forth around addresses $60000 and $70000. Most of the TFT startup and the menu, and Aaronix test screen logic are situated at $60000.
    • OneBus switching seems to be performed in RAM.
    • The TFT initialization seems to follow a pattern. There are multiple loads and stores, and digging the pattern in Google, the model is actually GC9306. Datasheet here.
    • The register $4233 possibly controls the 16-bit parallel LCD outputs to be a GPIO or the parallel LCD. When it is set at $84, this might becomes a GPIO - during the TFT initialization it does this. When done the initialization routines, this is set at $04
    • The functions that write the command and data to the TFT uses $4230 and $4231. At $4233 again if it is a write command, $94 is written. If it is a write data, $D4 is written.
    • Finally, around the starting point of the game menu, $412C is written $0F to enable the backlight.
    These are also verified using the homebrew flash emulator that dumps part of the ROM ($60000-$80000) into the Teensy 4.1.
    With the flash emulator, using the stripped ROM, I managed to try adding a while loop at certain places in the ROM (usually 4C xx xx) to 'halt' the program. This is useful when I want to see when the backlight gets switched on. Initially, it is thought that the backlight is switched on at the TFT initialization routines. However, putting the command inside does not work (backlight doesn't lit up), and I had to try adding this 'halt' between the function calls when the menu is running. When one of the locations are being known to switch on the backlight, I focused into it and found out that putting the $0F into the $412C actually does this thing.
    I dumped two of these ROMs (one bought in 2020, and another somewhere later) and one of them have swapped bits 1-2 and 9-10 at the data pins! Some of them have very different starting vectors too - one started at $FF00, and one at $FEF5. However, they all use the same mentioned registers and these apps could possibly work on another similar Sup 400-in-1 consoles.
    One more issue - where are the registers that controls the external sound speakers?
  • It is working, but might not be fully functional!
    YH-workshop03/23/2024 at 16:54 0 comments
    After looking at the code and checking the Teensy 4.1's processor datasheet, it is known that there are edge interrupts on a row of GPIO pins. It means, if any pins at GPIO6-9 are changed, it triggers an interrupt.
     I'm suspecting that the polling of the address lines by Teensy couldn't catch up with the speed of the switching addresses at the NOAC. Having the pin change interrupt makes it easier for the NOAC to catch the instruction that is fed from the Teensy pins.
    And... yes, there's the game menu, and it jumped into the test screen when I hold the A + B before the thing starts:
    Unfortunately, there are limitations - the Teensy needed to be overclocked to 912MHz to do this successfully, and a heatsink is required. I am now figuring a way to have a fan to blow on the heatsink, and also to write up short pieces of 6502 code to make it run on that NOAC.
    And here's the Github page if you are interested in replicating the project.
View all 23 project logs
Zibri wrote 12/26/2024 at 12:25 point
I bet that they don't do all this to program them. Perhaps the USB port is not only for power.
e64 wrote 04/05/2024 at 12:18 point
one small questions. Is possible replace cpu to arm cortex-m or raspberry pi pico
YH-workshop wrote 04/11/2024 at 03:34 point
Hi, it is possible - you may need to replace the entire circuit board with your own microcontroller. There is someone who actually created a custom PCB to fit inside the handheld. However, this is beyond the scope of the discussion. :D
e64 wrote 04/11/2024 at 20:20 point
Yes, this is beyond discussion. I thought it would be a simpler way to use the whole board, display, power supply but replacing it with a known cpu
You are planing runing fuzix on this dev?
Breyos wrote 10/14/2023 at 05:24 point
I found one of these things at Walmart, and thought it looked interesting enough to crack open and take a look inside! Mine came with one of the button contacts missing, so I couldn't "right" in any of the games. I was hoping to maybe replace the microcontroller inside, but I had no idea it would essentially be a NES emulator!
YH-workshop wrote 04/11/2024 at 03:35 point
Apologies for the late reply - it's not an NES emulator, but it is a heavily modified Famiclone on a Chip. This one possibly uses a VT-02 or VT-03 ones as it can run using the EmuVT emulator.
fdd wrote 03/29/2023 at 16:09 point
Hi, I love your project!, I wonder if there is some place to download a full dump of memory to test it in the emulator. Links in 4pda forum are broken. Regards
Starhawk wrote 10/17/2020 at 17:20 point
Re 16bit "6502" CPUs... look up the 65C816 from Western Design Co aka WDC ;) 6502[dot]org may or may not have the data sheet, along with that of their 65C02 (which is slightly different from the more common Rockwell/etc versions)... can't remember. But WDC (not the same WDC as the one that makes hard drives and SSDs, obviously!) publishes their own datasheets, if nobody else does... ;)
