Hackaday.io Hackaday.io
Sign up Log in
Home environment monitoring system
A bunch of sensors
tauno-erikTauno Erik
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
4 comments
428 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 4
View Gallery
633
4
428
11
Team (1)
  • tauno-erikTauno Erik
Join this project's team
  • taunoerik.art
  • github.com
hardware
ongoing project
This project was created on 11/19/2020 and last updated 6 years ago.
Description
Sensors will measure particulate matter (Ultrafine dust PM2.5 and fine dust PM10), co2, TVOC, ambient light, humidity, temperature and barometric pressure.
Details
Log In/Sign up to comment
Sign up with Github
OR
Ken Yap wrote 11/19/2020 at 22:32 • point
👍 With the artistry of this project one could spend a lot of time monitoring the monitoring system. 😀
Tauno Erik wrote 11/20/2020 at 14:52 • point
Thank You!
Dan Maloney wrote 11/19/2020 at 21:09 • point
Love the look of this. Are there two different kinds of wire or is that just the way the photograph was taken?
Tauno Erik wrote 11/20/2020 at 14:53 • point
Yes, there is two different colour wires: bronze and silver.
A FeatherWing for air-quality, light, pressure, humidity, and temperature measurements, featuring also SD Card and Grove connectors.
Project Owner Contributor
Environmental Sensor FeatherWing
alex-tsamakosAlex Tsamakos
Very low cost, easy to make 1-wire temperature sensors
1-wire temperature sensor inside light switch
andrewcrockfordandrew.crockford
A way to accurately measure air to air heat exchangers
Heat exchanger testkit
yvo-de-haasYvo de Haas
SmogWatch is a WiFi enabled smog (air quality) meter based on ESP8266 (ESP-12). It also measures temperature, humidity and atmospheric press
SmogWatch - WiFi enabled smog sensor
piotr-sperkaPiotr Sperka
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Home environment monitoring system", please tell us the reason.
Send message
Remove Member
