LiFePO4wered/Pi400
Simplified low cost UPS and battery power for the Raspberry Pi 400
I had been playing around with ideas for a simplified and lower LiFePO4wered UPS for the Raspberry Pi, and then the Foundation came out with the Pi 400, which seemed like an excellent target for this since it can't use my existing LiFePO4wered/Pi+ (or at least would look very weird with that sticking out the back :)).
Goals are lower cost, simplified functionality, but great performance, safety and long life as usual. The idea is that this will be styled like a cartridge that plugs into the back of the Pi 400 in the GPIO port, but duplicates the GPIO port on the other side so it's still available for other things.
Physically this will be a cartridge that plugs into the GPIO port on the back of the Pi 400, with a duplicate GPIO header coming out the other side so it is still available for other uses.
External power will be connected to the existing power input of the Pi 400, so this will only be dealing with 5V.  Not dealing with higher voltage input and things like solar will simplify this a lot.  The system will boot when external power is connected to the Pi 400, and if external power is removed, a clean shutdown will be triggered after which power will be removed.  Or the user may have the option to keep running from battery power.
There will be a button to turn on the Pi 400 from battery power and to trigger shutdown, but since the system will be powered using the Pi 400's own power input, it's not possible to remove this power when it's plugged in.
One special feature I'm trying out in this design is to use the Pi's own power input, and use the 5V GPIO pins both to charge the battery when external power is present and supply power when external power is removed.  I will be using a boost converter with true output turn-off, and the goal is for it to be enabled while external power is present, primed and ready to take over as it were.  Its setpoint will be slightly less than the incoming 5V, I'm starting with 4.85V.  Since the 5V rail will be at higher voltage than its setpoint, it should be at 0% PWM, not doing anything.  Then when external power is removed, the voltage will start to drop and the boost converter should kick in, ramping up PWM to maintain the voltage at 4.85V.
  • Shelved it
    Patrick Van Oosterwijck • 12/10/2021 at 20:54 • 3 comments
    This project has been shelved because the Pi400 load switch on the 5V GPIO makes it pretty much impossible to reliably power the thing through the GPIO.  Too bad, but not much can be done about it.
  • Some bad and some good
    Patrick Van Oosterwijck • 12/02/2020 at 23:26 • 1 comment
    Having established that when the Pi 400 is on, the load switch can conduct both ways, it was time to check whether the UPS can keep the Pi running when external power goes away.  I connected the prototype to the Pi 400 and the debug probe.  I had some init code to set the pins correctly, after which I paused execution and used the IDE to manually enable the boost converter.
    Then the magic smoke came out. :(  What the heck?
    Yep, the boost converter burned out.
    I am very confused.  I had already checked that the boost converter did the right thing when external power was applied in the very first project log I thought?  The only difference is that I checked it with a lab supply instead of a Raspberry Pi (and its supply).  Could this make a difference?  Does anyone have an explanation as to why this would work when the external voltage is applied by a lab supply versus a wall wart?
    I guess I'm happy it blew up so early in the project versus much later, after doing a bunch more work.  The worst case would have been if it all seemed to work while I was prototyping and developing the whole thing with one particular supply, and then blew up when someone used another supply.  My only loss now is the layout work and three prototype PCBs.
    So, where to go from here?  Well I don't feel like giving up just yet.  It's not because a specific part fails that the whole concept is trash.  So I decided to test the concept with a really simple setup.  I connected a test circuit with two tiny 100 mAh LTO (Lithium Titanate) cells in series to the 5V GPIO.  The nominal voltage of LTO cells is 2.4V, so two of them in series is close enough to 5V.  LTO cells have low internal resistance, so even small cells have high enough current capability to power a Pi.  For a short time at least.
    Plugged in, time to pull the power cord:
    Excuse the mess on my desk, but you can see the Pi 400, with power cord pulled, still running from the two little purple LTO cells!
    How long can it run?  Well I did some testing with even smaller 60 mAh LTO cells.  Running the "stress" test utility, it lasted about 10 seconds.  Playing a video in the browser, about 22 seconds.  Just idle at the desktop, I stopped the test after a minute but it was still going.  I think the limit is not so much the capacity of the cell, but the voltage loss due to the cells' internal resistance and the loss across the Pi 400's GPIO 5V load switch.  When the battery voltage gets down to about 4V, the Pi turns off.
    So if shutdown is immediately triggered when loss of power is detected (terminating high load processes with it), this may be a workable design!  I may not even need to add a power switch on the UPS, I could actually take advantage of the load switch in the Pi 400 which drops leakage current into the 5V pin to less than 1μA!  But I probably will, because of the 40-pin header pass-through design I'm going for.  The key to making it work will be to accurately detect whether current is flowing into the battery or out of the battery to the system, and immediately signal a shutdown to the Pi when power is provided by the battery.  I may be able to salvage the current sense amplifier circuit from the failed design for this purpose.
  • Raspberry Pi 400 analysis
    Patrick Van Oosterwijck • 12/02/2020 at 17:08 • 2 comments
    I finally received a Raspberry Pi 400:
    Time to take it apart and see what's going on with the GPIO 5V!
    Most reviewers talked about the top size of the PCB and pretty much ignored the bottom.  Contrary as I am, of course my main interest of course is on the bottom, specifically with these two parts:
    These are identical parts, presumably the load switch talked about.  Two of them: one to switch 5V and the other to switch 3.3V.  The one in the center definitely drives the GPIO 5V pins, the other one switches 3.3V but oddly is not connected to the GPIO 3.3V!  I think it switches the SD card slot power.  Protect the one GPIO power rail but not the other?  I don't get it.
    They are marked "0F=11R".  It took some digging to find what exactly they are, but eventually I figured out that they are almost certainly Richtek RT9742 load switches.  The connections match the datasheet, as does the "0F=" marking.  Oddly, two variants are both marked "0F=": the 3A RT9742ANGJ5F and the 1A RT9742GGJ5.  The only difference to tell them apart is that one of them is in the "TSOT-23-5" package and the other in the "TSOT-23-5 (FC)" package.  But if you check the mechanical outline specification for these packages, they seem to be identical according to the spec.  I don't know what the supposed difference is then.
    So I decided to just test which one it is.  I hooked up my electronic load, and increased load from 1A up in 0.1A steps.  It tripped at 1.4A, so it's the RT9742GGJ5 1A version.
    The datasheet has this info about the pass transistor: "Unlike a normal MOSFET, there is no parasitic body diode between drain and source of the MOSFET, the RT9742 prevents reverse current flow if VOUT is externally forced to a higher voltage than VIN when the chip is disabled."  So indeed no hope of turning the Pi 400 on from GPIO power.
    Once the Pi is on, it may be possible to preserve power long enough for shutdown though.  The datasheet says: "If VOUT is greater than VIN, current will flow from VOUT to VIN since the MOSFET is bidirectional when on."  So UPS functionality is still possible.
  • Problems
    Patrick Van Oosterwijck • 11/23/2020 at 22:51 • 1 comment
    I guess that one update was where the good news ended. *lol*
    I found out today that the Pi 400 seems to have a 1A load switch on the 5V pins going to the GPIOs.  Not that there's any good way to find out since I can't get hardware here and the Foundation still hasn't bothered to release schematics!  Lately it's like they are actively working to try and make the life of third party developers such as myself difficult.  They've never been the poster child of openness, but it's getting worse all the time.  It's like they're trying to become Apple, making shiny consumer gadgets and have forgotten their original mission of providing a hackable product.
    Anyway, if this is the case, the approach I'm taking here likely won't work.  Not sure if anything would work really.  It is possible that once the load switch is turned on, I can send power back to the Pi.  But I don't know by what mechanism the load switch is turned on.  Also, it's a 1A load switch so depending on how much other stuff is connected to the USBs etc, there may be more than 1A flowing through it once I'd start to power the Pi.
    It pretty much means that "running the Pi 400 from a battery" is pretty much out.  Working as a UPS may still be salvageable.  Only testing will tell.  This topology may need to morph back into the original "simple UPS for a normal RPi" if it doesn't work for the Pi 400.  The Pi 400 may need a different approach, involving only the USB Type-C power input.
    I also did some load testing on the G2263 boost converter.  This is supposed to be a 9A switch current part, a "compact solution for a 5V output, 4A load requirement" according to the datasheet.
    Well, in my testing it seems to be a whole lot less than that.  I don't know what the limit is, but when I tested at 2A, the part got very hot (>150 °C, the maximum my FLIR can measure) and went into a hiccup mode (probably thermal protection kicked in to try to save the part from burning up).  I tested it at 1.5A load and this is the thermal image for that:
    Still very hot but at least it seemed stable.  This heat production is another indication that UPS duty may be a doable goal while running for long periods from the battery isn't really.  The part can provide 1.5-2A for a short period of time, long enough for shutdown to complete.
    I have also confirmed that the current sense amplifier seems to do its job (although the reading seemed a bit high, but that might just be due to trace resistance that isn't yet taken into account).  It outputs a positive voltage versus a reference when power is produced from the battery and a negative voltage when the battery is charging.  That should do the job for being able to detect whether external power is provided to the Pi or we are providing the power from the battery.
  • Prototype build
    Patrick Van Oosterwijck • 11/23/2020 at 05:37 • 0 comments
    After creating the design, I ordered prototype PCBs and stencil from JLCPCB.  This log documents the build of three prototypes.
    The SMT part of the build went very smoothly.  No obvious shorts I needed to deal with.  Two parts are still missing: the button (SW1 which didn't arrive yet and I'll add later) and there's a footprint for a low cost 6-pin Padauk micro (U7) which will be used to enable firmware update of the MSP430 over I2C BSL.  No point in mounting an OTP micro until I've figured out its programming. :)
    After such a smooth SMT build, connecting the headers unexpectedly was a whole lot more troublesome:
    Ugly, I know.  I had a lot of trouble getting both the pads and pins to wet and connect.  In hindsight, the pads are too small as they are completely under the pin so they're hard to heat together with the pin.  Also, the board is thinner than the spacing between the two rows of pins, so there's a gap that needs to be bridged.  I'll have to investigate thicker PCB options for a better fit.
    I got a prototype together in the end:
    The battery holder for an 18650 LiFePO4 is on the bottom of the board.  I was able to confirm some basic functionality:
    • I could connect to the MSP430 microcontroller using the MSP430-FET.
    • I could enable the 32 kHz crystal oscillator for system clock generation and RTC timekeeping.
    • The battery would charge when external power was connected and charging enabled.
    • The boost converter would generate ~4.85V when enabled (I did not test current capability yet).
    • The boost converter could be enabled while external power was applied and nothing would blow up!  The boost converter would simply stop switching with the voltage above its setpoint, and start up as the voltage would start to drop when external power was removed.
    This last test was really important, the whole concept of this UPS would stand or fall with the result of this test.  And as far as I could tell, it passed with flying colors!  I could have the boost converter enabled and apply and remove external power at will, the boost converter would just take over when external power went away and stop providing power when external power came back.  You could see the voltage on the scope go from 5V to 4.85V and back to 5V and the whole thing would be completely glitch-free!
    Next things to test:
    • Output current capability.
    • ADC measurements of system and battery voltage.
    • ADC measurement of input/output current, and the accompanying detection of whether we're supplying power or external power is present.
    Once these are confirmed, I can start writing the firmware for this new micro.  It's still an MSP430 like in the #LiFePO4wered/Pi+, but this is a newer generation device with FRAM and enhanced peripherals compared to the part I used in previous designs, so some porting will be necessary.
View all 5 project logs
RKM wrote 12/08/2020 at 23:40 • point
So I was wondering if you or anyone else would be able to provide any info on that ribbon connector used for the keyboard portion of the Pi-400. I haven't been able to get my hands on a Pi-400 yet, but I've got this idea of putting one inside of a custom mechanical keyboard. I'm curious what the interface between the keyboard and the main board looks like. I'm guessing there's some kind of MCU on the other side of that cable, but it's also possible that it's going straight to a matrix encoder.
This whole thing would be a lot simpler if the Pi foundation would actually update their hardware schematics. It's really annoying that they seem to have gotten so lax about keeping those up to date.
Arya wrote 11/25/2020 at 12:19 • point
Hey! Sad to hear about problems, it must've been quite an investment. Wish there were schematics - I also invested money in my own Pi 400 adapter, and there were no schematics to guide me either, I ended up following the "Pin 1" and "Pin 40" markings on the board case. Oh boy I sure hope there aren't any hidden problems with my design!
Your board design is quite nice, BTW. You could add some through-hole pads for the 40-pin connector and allow people to plug HATs onto it, like the adapter I've done ( https://www.tindie.com/products/21769/ ), I have a feeling that it's something users would appreciate. You do need to flip all the pins if you want the HAT to extend away from the keyboard (probably the most ergonomic solution), but that can be done on a 2-layer board, let me know if you have questions about that.
Save for the power dissipation problems - as the Pi 400 can be disassembled, perhaps you could still sell the adapter with a requirement that the user mods their Pi 400 by installing a jumper wire bypassing the load switch? As long as people are aware that disassembling their Pi 400 and soldering a wire inside is required, there should be no problems.
Alternatively, add two Type-C connectors in the next revision for pass-through power configuration... though then you probably don't even need the GPIO header?
Patrick Van Oosterwijck wrote 11/25/2020 at 15:50 • point
Thanks for your encouragement!
That's quite an undertaking you did there, flipping that whole header around!  Nice work.  For this design, the goal was pass-through from one side to the other, which was plenty of work in itself while keeping the ground plane reasonably solid within the individual subsystems.  The intent was for this to be in a "cartridge" plastic case, so I don't think the "facing up" header would be useful in this design.  If someone wants that, they can add yours to the pass-through header of mine. :)
If this cartridge idea is indeed a dead end, I'll be looking at doing something with the Type-C power input, which should work if it has the data lines connected (anyone know?).  It will just make everything more complicated, and an inline battery blob seems like a less attractive design than a cartridge, but that might be a matter of taste.
Arya wrote 11/25/2020 at 15:53 • point
What do you mean by "if it has the data lines connected"? You mean, USB data lines, or CC lines, or something else?
Oh also, you do power management by using some Pi GPIOs, right? Or do I remember it wrong?
Patrick Van Oosterwijck wrote 11/27/2020 at 02:34 • point
Yes, I mean USB data lines.  I could possibly communicate with the host system using that instead of I2C.
I currently use I2C and monitor the TX output to detect system shutdown.
Arya wrote 01/05/2021 at 11:09 • point
There should still be USB data pins connected to the Type-C socket and they should still work for both host and gadget applications. Your current approach of "communicate using I2C and monitor TX" seems okay to me, but perhaps you can indeed make some sort of host script that send a small packet to a USB-connected MCU right before shutdown. Let me know if you need help with this (preferably, in the DMs), I have researched the "run script right after shutdown ends" thing for some time.
