Time to go on other projects
01/03/2021 at 02:23 • 0 commentsLast update for this project for now. It works well and served as a proof of concept. This was a good exercise to use the on-chip peripheral for generating a trigger output for an oscilloscope. It uses only a Microchip ATmega328PB, a few swiches and components.
I won't be needing this for myself anymore since I have a scope with this feature built-in.
Project development completed
01/02/2021 at 22:26 • 0 commentsI finally made this project work after much head scratching.
The result is a stable trigger output for any scope. This version uses common push button switches.
The design could use capacitive switches instead with the Q switch library. To be tried next.
Jacques Pelletier
