#Zepir Raspberry Pi Zero mini computer
on rpi GPIO is enough signals to direct button matrix + 2" IPS 320x240 display.
I love my keyboards, looks on RPI GPIO is enough signals for direct keyboard matrix scan
+ 2" IPS 320x240 display ST7789
+ REALY NOTHING MORE !!!!!
No extra manufacturing, front panel is made in PCB factory + mainboard
Keeping my KISS philosophy make it stupid simple = one order = one device
First preview :)
There nothing, just display and buttons ;)
  • Display configuration
sudo apt-get install cmake
cd ~
git clone https://github.com/juj/fbcp-ili9341.git
cd fbcp-ili9341
mkdir build
cd build
cd fbcp-ili9341/build
rm -r *
cmake -DST7789VW=ON -DGPIO_TFT_DATA_CONTROL=25 -DGPIO_TFT_RESET_PIN=27 -DGPIO_TFT_BACKLIGHT=24 -DSTATISTICS=0 -DSPI_BUS_CLOCK_DIVISOR=6 -DUSE_DMA_TRANSFERS=OFF -DDISPLAY_ROTATE_180_DEGREES=ON ..
make -j
sudo ./fbcp-ili9341
For autorun on startup put this line before exit 0 in your sudo nano /etc/rc.local
sudo /home/pi/fbcp-ili9341/build/fbcp-ili9341 &
sudo modprobe -i uinput &
sudo python /home/pi/keyboard/keyboard.py &
sudo setfont /usr/share/consolefonts/Lat2-Terminus20x10.psf.gz &
 These lines are in my sudo nano /boot/config.txt file:
hdmi_group=2
hdmi_mode=87
hdmi_cvt=320 240 60 1 0 0 0
hdmi_force_hotplug=1
Change in driver before compilation st7735r.h
#if defined(ST7789) || defined(ST7789VW)
#define DISPLAY_NATIVE_WIDTH 240
#define DISPLAY_NATIVE_HEIGHT 320
#elif defined(ST7735R)
#define DISPLAY_NATIVE_WIDTH 128
#define DISPLAY_NATIVE_HEIGHT 160
#elif defined(ST7735S)
 Change in driver before compilation st7735r.cpp
#ifdef ST7789
    // The ST7789 controller is actually a unit with 320x240 graphics memory area, but only 240x240 portion
    // of it is displayed. Therefore if we wanted to swap row address mode above, writes to Y=0...239 range will actually land in
    // memory in row addresses Y = 319-(0...239) = 319...80 range. To view this range, we must scroll the view by +80 units in Y
    // direction so that contents of Y=80...319 is displayed instead of Y=0...239.
    if ((madctl & MADCTL_ROW_ADDRESS_ORDER_SWAP))
    //  SPI_TRANSFER(0x37/*VSCSAD: Vertical Scroll Start Address of RAM*/, 0, 320 - DISPLAY_WIDTH);
        SPI_TRANSFER(0X37,0,0);
#endif
  • Keyboard reading is based on:
https://mrpjevans.com/zx-raspberry-version-2/
https://github.com/mrpjevans/zxscanner2/
keyboard.py
x-python - 6.25 kB - 06/27/2021 at 21:43
Download
z3.sch
sch - 512.11 kB - 06/23/2021 at 21:03
Download
z3.brd
brd - 149.24 kB - 06/23/2021 at 21:03
Download
Portable Network Graphics (PNG) - 39.99 kB - 06/23/2021 at 21:02
Preview
  • Installation v2 - My private notes ;)
    bobricius10/01/2021 at 21:04 0 comments
    My private notes ;)
    My steps:
    Write image: 2021-05-07-raspios-buster-armhf-lite.img
    copy to boot:
    empty file ssh
    wpa_supplicant.conf
    country=SK
    ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
    update_config=1
    network={
        ssid="mynetwork"
        psk="mykey"
    add in to config.txt
    [all]
    hdmi_group=2
    hdmi_mode=87
    dtparam=audio=on
    start_x=0
    dtoverlay=audremap,pins_18_19
    dtparam=i2s=on
    dtparam=spi=off
    display IP address
    ifconfig
    via ssh
    Login: pi
    password: raspberry
    $ sudo raspi-config
    SET AUDIO > headphones
    boot console autologin pi
    DISPLAY SETUP
    sudo apt-get update
    sudo apt-get install git
    cd ~
    git clone https://github.com/bobricius/fbcp-ili9341.git
    cd fbcp-ili9341
    rm -r *
    cmake -DST7789VW=ON -DGPIO_TFT_DATA_CONTROL=25 -DGPIO_TFT_RESET_PIN=27 -DSTATISTICS=0 -DSPI_BUS_CLOCK_DIVISOR=6 -DUSE_DMA_TRANSFERS=OFF -DDISPLAY_ROTATE_180_DEGREES=ON ..
    make -j
    sudo ./fbcp-ili9341
    Extra toys
    sudo apt-get install mc
    sudo apt-get install w3m
    sudo apt-get install mpg123
    KEYBOARD SETUP
    cd ~
    git clone https://github.com/bobricius/gpiokeyboard.git
    pip3 install python-uinput
    sudo python3 /home/pi/gpiokeyboard/gpiokeyboard.py &
View project log
Rich text editor
torincampbell1 wrote 07/24/2024 at 00:25 point
I want to see this but with a pico :)
LAPINI wrote 01/31/2024 at 22:37 point
Does it support Hebrew?
Trevor O'D wrote 02/28/2022 at 22:37 point
what are the dimentions of the device I am trying to make a case for mine so I can carry it around
bobricius wrote 03/01/2022 at 11:42 point
Dimension:97.79 mm* 82.56 mm
Trevor O'D wrote 02/18/2022 at 02:26 point
Is there a  case out there for this or would I need to make my own
bobricius wrote 02/18/2022 at 07:36 point
No case designed
teraz wrote 11/03/2021 at 21:36 point
how long this device work on one charging? is possible add solar panel?
John Hind wrote 05/29/2021 at 10:17 point
Love the keyboard concept - might have to steal it for my next-gen calculator project! But this would be a lot neater as an IO board for the Compute Module 4. The whole assembly could be much more compact (depending on how many and what type of connectors you chose to implement).
bobricius wrote 06/07/2021 at 21:13 point
Zepir is specially designed to be max. simple, zero integrated circuits, TH soldering :)
Sam Garfield wrote 04/16/2021 at 20:22 point
Will you be selling a complete version on tindie?
xxx wrote 04/15/2021 at 17:07 point
Where i can download gerberbers for repeat this project?
bobricius wrote 04/15/2021 at 21:17 point
I preparing share next version (bot is untested now), this have some bugs.
xxx wrote 04/16/2021 at 08:00 point
Great! I will wait for relaese gerbers.
marazm wrote 02/04/2021 at 11:54 point
Dodaj kilka diód. Chodzi o informacje czy wciśnieęto capslock, ins, czy przyszła poczta itp.
Myślę, że warto też zrobić miejsce by można było tam wstawić raspbery pi pico 2040 lub jakieś inne procesory. Jak by było to autonomiczne bez zasilania po kablu to wiele osób by chciało miec komputer na swoim *(tu wpisz procesor) ulubionym procesorze
aldolo wrote 01/28/2021 at 06:39 point
keyboard is always the toughest part. cheap and brilliant solution.
xxx wrote 01/27/2021 at 08:28 point
In general, it could be diluted through Atmega32u4, making both the mouse and the keyboard at once, and dissolve on the board itself USB-HUB FE1.1s for 4 ports
xxx wrote 01/27/2021 at 08:25 point
looks very interesting, the only thing I would add at the place where the palm is shown is a trackball or joystick  to control the mouse cursor
Anthony DiGirolamo wrote 01/19/2021 at 06:31 point
Looks great!!! I like your key layout. If it helps free up GPIO pins you could use a TCA8418 which has linux kernel module support. Kicad and links here https://github.com/AnthonyDiGirolamo/i2c-thumb-keyboard
Your design is a perfect form factor for coding & gaming on the go with https://www.lexaloffle.com/pico-8.php
bobricius wrote 01/19/2021 at 12:34 point
Thanks, Yes I know this, but look like I have exactly enough GPIO for full keyboard. I love simplicity :-) I just ordered 2 Boards batch (maybe next revision can fit over RPI 3/4), receive soon.
ptrav wrote 01/10/2021 at 02:37 point
Interesting project.
On your keyboard wiring diagram, one problem is obvious.
Let say, you keep all "columns" high and set all "rows" as "input-pullup". Then, you scan  the columns by setting one column "low" in a cycle and testing all inputs one-by-one. The pressed button will be on the crossing between the column pulled "low" and the row showing "low". As far as the user presses one button at the time, all good and sound.
What happens, however, if the user presses 2 buttons of the same row? Let say, column #1  is momentary "low" and column #5 is "high". Then, column #5 will feed 3.3V at unlimited current into the column #1. One of the digital outputs - most likely the column #5 - will fry. It is a good idea to put a diode at each column to prevent this.
The way of circumventing is not to use pins as digital inputs but use the internal resistors:
GPIO.setup(button, GPIO.IN, GPIO.PUD_UP)
All 6 columns are set to GPIO.PUD_UP and one of them set to GPIO.PUD_DOWN at any given time. The internal 50k resistor will limit the current and the outputs will not fry.
One more problem remains. If the user presses 3 buttons simultaneously, a "ghost" (unpressed) button will register. For example if the user holds buttons C1R3, C2R2, and C2R3 - button C1R2 is registered. That's why each key should have its own diode. However, on a tiny keyboard like yours people are unlikely to touch-type, so may be these diodes are excessive.
The good explanation of matrix keyboards is here:
http://blog.komar.be/how-to-make-a-keyboard-the-matrix/
Good luck with your project.
