This computer can run Microsoft BASIC and the Scrumpel monitor originally made for 68HC11 but ported to 6809.
I also wrote a Forth for it.
Nforth evolves, here the next version:
This is the newest one with extra features
An 68B09 SBC with 16KB ROM and 32KB RAM, 8 bits I/O and 2 serial ports @ 115200 baud.
scrumpel8monitor.pdfManual of the Scrumpel monitorAdobe Portable Document Format - 229.04 kB - 10/01/2021 at 18:42 |
nforth.hexThis is my own created Forth, Nforth for 6809. It loads at $0100 and runs on that address also. You can load it with the loader of the Scrumpel monitor. I removed a datastack check for speed reasons. This is a version which uses USP in stead of IX and I removed an error in the word dump.- 14.55 kB - 04/20/2021 at 07:36 |
mon6809.asmOn request, the scrumpelmonitor sourcecode. I use ASL as crossassembler.asm - 17.71 kB - 04/09/2021 at 06:14 |
othello.hexA game called othello for the 6809 computer. It resides at $3100 and is loadable with the intelhex loader from the monitor. Its startaddress is $3100hex - 6.58 kB - 03/31/2021 at 17:05 |
scrumpel8bv1_1.zipNew gerber files using Scrumpel8bV1.1 schematic.Zip Archive - 146.52 kB - 02/17/2021 at 08:02 |
I placed the corrected schematic from Scrumpel8b, this will work as expected. TSC wasn't connected what caused that the CPU goes randomly into tri-state so the program wasn't executed in the right way.
First publishing of all info for Scrumpel8 an 6809 SBC
Pin 39 TSC of the 68b09 must be connected to ground to work properly. In version 1.1 this is solved..
Nforth is a project in progress, I placed the hex file because it can be used for this Scrumpel 8 system. It has special words for the I/O port from Scrumpel. It is my own Forth dialect and is not fully compliant with any Forth standards. It is still experimental also.... It is not optimized for use in 6809 yet, because I ported it from my 68HC11 version. I use the X register as datastack, but in 6809 you could better use the user-stackpointer..... It is subroutine threaded, so I can use calls to words and machinecode. As long it's experimental, I won't post the sourcecode..... I don't want to publish incomplete or faulty sourcecode.
With my Cortex-M Forth, zeptoforth, I keep it on GitHub and continually update it there so people can see the changes to my code - it is not going to be a finished product for quite some time, if ever, and I am not going to wait for then before I let people see my code (especially since much of the zeptoforth environment is actually written in Forth).
On your request I publiced the sourcecode of the Scrumpel monitor program. Have fun with it.
Hi Nick:
Nice work. :)
I'm searching for monitors for my own Grant Searle'ish 6309SBC and SCRUMPEL looks good. Are you planning to release the source code? Or at least a source for the 68HC11 version of it?
Peace and blessings,
JQ
The Forth I made it originally for my 68HC11 from scratch. I ported it for 6809 which was not to difficult. I use the Grand Saerle BASIC . I have the BASIC in ROM plus my Scrumpelmonitor ported from the 68HC11. The Forth runs from $0100 and I load it with my monitor into memory.
Nice project :-)
Did you make your Forth from scratch?
Which legacy system was the source for the BASIC?
How do you deal with persistence of programs, both in Forth and in BASIC?
FloppidyDingo
Keith
Robert Rico
Bernhard "HotKey" Slawik
On github the monitor and nforth source-code are published.
