Portable Foldable Scoreboard
A portable, scalable and foldable display, that can be used as a Scoreboard or Timekeeper in outdoor sport events, with minimal setup
Starting from
has orders / reviews
Ships from
A simple, scalable and foldable display, that can be used as a Scoreboard or Timekeeper in sport matches.
Quite useful for indoor and outdoor sports, as it's very easy to setup (all you need is a place to hang it!).
The visibility is really good, it can be easily read from 50+ metres, even in sunny days
Display is made with the popular WS2812 strips. The current prototypes use the IP65/30 version, fixed into PVC bars. The 15x9 resolution can then be achieved with a single 5m strip
The frame is based in modified 3dprinter cable chain slabs, with fixings to held the PVC bars with the leds. The vertical separation of each bar matches the strip horizontal distance between LEDs, to keep the aspect ratio.
There are two versions of the CPU for the controller:
- one based in the cheap STM32 bluepill, which is embedded in the handheld controller
- another based in the also cheap ESP8266 board, which can be controlled by an app in the phone.
Both use the LVGL graphic library, which supports basic animations and high resolution colours. Text is set to the smallest supported size, 7x5, so it fits in the small resolution
It's powered with a standard USB power bank, making the whole project very portable.
scoreboard.pdf
STM32 Bluepill wiring schematics
Adobe Portable Document Format - 66.29 kB - 06/08/2021 at 15:29
Preview
WS2812B.pdf
WS2812 datasheet
Adobe Portable Document Format - 347.03 kB - 05/31/2021 at 17:52
Preview
  • 1 × WS2812 Strip
  • 1 × STM32F103C8 Bluepill
  • 2 × Pushbuttons
  • 9 × 12x3x500 PVC bar
  • 18 × 3d printed chain slabs
View all 7 components
  • LED Strip frame
    LordGuilly06/12/2021 at 11:17 0 comments
    The frame is based in a common 3d printer chain accessory, for holding the cables.
    I had to adjust it a bit:
    - made it longer so it matches the distance to have the right aspect ratio.
    - added a side strip to fit the PVC bars where the LED strips will be placed
    - split the top, which is a separate part. This way the assembly and maintenance of the wiring is much more easier, as the LED strips can be mounted, and then the cables soldered.
    Parts are in Thingiverse
    https://www.thingiverse.com/thing:4884051
  • Source code for the STM32 available
    LordGuilly06/09/2021 at 18:34 2 comments
    It probably still needs more tidy up, but I uploaded the code to Github.
    At the moment, it's expected to be uploaded to the Bluepill by the dapboot bootloader, so the "make" output won't work out of the box.
    The steps would be to flash a FW image of the dapboot bootloader to the Bluepill with the ST tools , and the use the DFU tools to flash the application.
    It sounds unnecessary complicated for a development stage, but it's a better solution in the long term, as it will allow normal, non technical users to upgrade the FW.
    Hopefully will be able to upload more instructions and tidy up some things in the next couple of days
  • STM32 BLUEPILL CONTROLLER
    LordGuilly06/08/2021 at 12:14 0 comments
    Bluepill based CPU. Tried to keep the wiring and soldering minimal, I think it was a good result!
    The board is powered from the LED strip connector, and the 7 pin header is for the buttons. As that side of the board has 2 ground pins and a 3V3, I used for pulling up/down the input buttons.
  • The LVGL project library
    LordGuilly06/06/2021 at 09:36 0 comments
    The scoreboard graphic requirements are simple, as it's just a couple of digits. But I didn't want to reinvent the wheel, so started looking at the available libraries in the internet.
    Basic requirements were
    - simple primitives for displaying numbers
    - availability for embedded systems, or easy to port if not
    - small memory footprint.
    It's not that I did a massive research, as I quickly found the LVGL project, which ticked most of the boxes. The website (https://lvgl.io/) described it as "GUI" oriented, and showed a lot of fancy things that I didn't need, but I decided to give it a go.
    The library resource used for the digits is called label, and each one need its own style defined. There is a hierarchy of styles, and they are inherited, so with one style per label, the individual colours or effects can be achieved.
    A label can be altered/changed wtih an animation. It's a simple way to, for example, move in, move out, scale, etc. At the end of the animation, a finish callback is called. By starting a new animation on it, you can do more nice and ellaborated things
    Once the basic setup is done, the library requires a periodic call to a task handler, lv_task_handler(). The period between calls needs to be reported by another API, lv_tick_inc(). The handler will call a "flush" callback if the graphic buffer changed (as a result of an animation, or an event).
    The flush callback is optimized to report smaller sections of the screen, to save time and memory. But that's not possible with the WS2812 driver method. So the flush callback simply sets a flag that will trigger a full display update in a different function.
  • Driving the WS2812
    LordGuilly06/03/2021 at 17:24 0 comments
    As mentioned in the previous log, the WS2812 is driven by a serial asynchronus square signal of 800KHz, and the duty will determine if the value transmitted is a '1' or a '0'.
    - if the signal is high for 0.8µs, and then goes low for 0.45µs, it's transmitting a '1' (duty cycle 64%)
    - if the signal is high for 0.4µs, and then goes low for 0.85µs, it's transmitting a '0' (duty cycle 32%)
    Now this timming can be a bit of pain to achieve if trying to do by "bitbang". By "bitbang" I mean setting level high, doing a couple of NOPS or dummy instructions, then setting it low, and so on for the total amount of bits required for all the pixels. And any interruption or asynchronous event will ruin the timming.
    I saw some projects use an SPI peripheral, setting its clock in a convenient way, and achieving the duty with the data bits. It's a clever way to do it, which has several advantages, including easing a lot the CPU usage. But it also makes the required memory grow significatively, as each pixel bit demands several bits of memory.
    So I went for a more basic/traditional/academic approach. The STM32F103C8 Timers can be configured to generate PWM signals on a pin, and use a DMA channel to load the following value. That way, if the LED strip is connected to the right pin, it can be refreshed with accurate timming and minimal CPU usage.
    As both peripherals are quite architecture/vendor specific, they are rarely used in frameworks like Arduino or Mbed, and require using the STM32CubeMx tool to generate the skeleton of the application. The timer channel is configured to generate a precise 1.25µs clock signal, and the PWM value in the channel will set the duty to 32% or 64% if it's a '0' or a '1'.
    I wrote the first couple of functions of the GFX_DRV module, and quickly realized the idea was not as efficient as I envisioned. Instead of 3 or 4 bits per pixel bit, I was now using 16 bits (that's the size of the timer compare register) per pixel bit. The code was simple to understand and debug, but not worth the memory budget.
    Yet I decided to keep it with some extra change. The refresh procedure was split into two levels, the Timer/DMA doing one full pixel at a time, and the CPU reloading the buffer with the next pixel values when the DMA cycle was completed.
    The memory overhead is now fixed to 48 bytes, independently of the screen size. The CPU, when the screen needs an updated, is required to reload the timer buffer every 30µs, which is not ideal. But as it's not doing anything else, it turned out to be acceptable in the end.
  • About the WS2812
    LordGuilly05/31/2021 at 17:41 0 comments
    The basic building block of the project is the WS2812 RGB LED. It's a popular part used in many projects in Hackaday, because it's chip and simple.
    The interface is a serial one, with a DataIn pin and a DataOut pin for connecting them in cascade. Each LED will use the first 24 cycles, and shift the rest from DI to DO so the next LED in the line can do the same.
    The period of each bit is 1.25 microseconds, and the duty will determine if it's a logic '1' or a logic '0'. A low level for 50 microseconds will cause the LED to update the colour value and start waiting for new pulses (reset condition).
    The LED will show the same colour until a new value is shifted in and a new reset condition happens. There is no need to periodically refresh the pixels, unless they actually change. The time between these "changes" can be any long.
    For this project, I used the IP65 strip, 5m length and 30 LED/m. As the resolution is 15x9, I have to cut each strip into 10 sections of 15 LED each, keeping the last one as spare. Sections are chained, to simplify the electric wiring, causing the data to go like a snake across the display. That way, only one pin of the MCU can drive the whole display (data flow is indicated with the red line in the image)
    Because each LED needs 24 bits, and there are 135 LEDs, the total time for shifting all the information is
    (24*1.25µS)*135 + 50µS =  4100µS = 4.1 mS
    That's quite reasonable, even for driving the LEDs in "bitbang" mode, which will basically block the CPU for manually toggling the input pin.
  • Working prototype demo video
    LordGuilly05/27/2021 at 20:12 0 comments
View all 7 project logs
LydaRA wrote 06/09/2021 at 17:23 point
Six characters wide?  Custom character maps?
LordGuilly wrote 06/09/2021 at 17:50 point
The character map is defined in LVGL, so you could potentially do anything that the library allows. There are bigger fonts, for displays with more resolutions, for example. The one used is 5x7 as it's the smallest.
Making it wider to fit more chars, I guess the bars that hold the LED strip needs to be a more rigid material. The PVC bars original size was 3m long, and their own weight cause them to bent. Maybe aluminium could be a reasonable tradeoff between stiffness and weigth. You would be looking on something 1.5m long though, that's bigger than I am willing to carry to my son's football matches :-)
I guess an extra "chain" (or two) could be also added in the middle, to improve the frame form factor and stability.
dennis.joslin wrote 06/08/2021 at 23:44 point
Just wondering if the Bluepill code is available?  I love the hardware, but am an extreme novice at coding.  Thank you!
LordGuilly wrote 06/09/2021 at 11:08 point
yes, still tidying it up for uploading!
dennis.joslin wrote 06/09/2021 at 12:04 point
Awesome, I can't wait to build this.  Thank you so much for sharing!
Ken Yap wrote 05/29/2021 at 09:57 point
That's a really neat idea. (Slaps side of my head for not thinking of it.) How is the durability of the strips with regard to folding and unfolding?
LordGuilly wrote 05/29/2021 at 12:12 point
Thanks, glad you liked it!
I have been using the same frame (chain slabs were printed in PLA), on a weekly basis, for a Junior football league. So far it looks good, after maybe 12/15 games (trials went on hold several times because of the Covid lockdowns!)
As the original chain slab design is for a 3d printer, I expect them to last, don't forget the scoreboard will not folded/unfolded too often (probably once a day for setup/removal).
dearuserhron wrote 05/28/2021 at 17:32 point
Make it display hackaday logo. Or animated allien from invaders game.
LordGuilly wrote 05/29/2021 at 07:28 point
At the moment, the prototypes are made with a 15x9 resolution, which is the minimum I need to display the smallest character size (7x5), and still use a single 5m strip of leds.
increasing the size is possible, but will severely affect the portability. Current size is about 55x30cm, I can carry it to games in backpack (which is quite practical!), I couldn't if it were much bigger :-)
Showing graphics is possible with the library, I can try to see what looks like, but can't expect much because of the small resolution
