PCB for HandWired Keyboards
Ergonomic typing, back in style
Public Chat
With these PCBs you can build your dream keyboard, now with lights!
thanks to the tiny size, this feature is included in any exotic DIY keyboard models like manuform
This project provides to handwired keyboards a support to have underglow keycaps. PCBs was designed for keyboard with different form factors, for example: dactyl manuform. Its geometry makes makers hard to desing flexible PCBs, and them could be available only for some kind of dactyl manuform. These 15mmx15mm PCBs are near to size of a keyboard Switch, so there can be placed in any custom keyboard, if a switch fits, a PCB will do it so, this is suitable for customizable keyboards. Every PCB was designed with a LED neopixel, 100nF capacitor and a 1n4148 diode.
Its tinniest size makes possible wire any keyboardboard you like.
 are you dreaming with a macropad? done! you can build it!
Form factor is not a problem!
Some Dactyl manuform has places where comercial PCBs doesen't fits correctly, this is not a problem now
Gerber_files.zip
PCB Gerber Files to upload and order to your PCB manufacturing service
Zip Archive - 17.61 kB - 07/18/2021 at 11:25
Download
keycap.zip
Entire kicad project
Zip Archive - 256.24 kB - 06/02/2021 at 22:57
Download
Dactyl_Manuform_BOM.ods
BOM with links of all components
spreadsheet - 14.09 kB - 06/02/2021 at 22:57
Download
  • 62 × PCB Electronic Components / Misc. Electronic Components
  • 62 × SK6812 4020 Electronic Components
  • 62 × Diodoe 1n4148
  • 62 × 100nF Capacitor
  • 2 × Arduino Pro Micro
View all 9 components
View all 9 project logs
View all 9 instructions
Oleksandr Kostian wrote 04/10/2023 at 22:29 point
Hi. I've seen manuals that mention the use of resistors. Was your keyboard assembled without resistors?
AlexTemp wrote 01/22/2022 at 15:16 point
Good afternoon. This is fantastic work and a great article. I have a question. Do I need keyboard reset buttons to install Arduino firmware? I am new to keyboard assembly. Where can I see a detailed tutorial on how to solder the switches? Thanks.
Pedro Barbero wrote 05/15/2022 at 19:43 point
Hi! Sorry for not answer you at time!
First time you upload the firmware you have to reset it manualy, but in the first firware you can set a pair of two keyswitches to reset the arduino as a software reset. Then won't be necessary use the arduino's hardware reset from the board.
AlexTemp wrote 05/17/2022 at 13:32 point
 No problem. I'll get back to the project when the war is over. Thank you.
Tom Nardi wrote 08/29/2021 at 20:17 point
Brilliant idea, love it.
Pedro Barbero wrote 08/30/2021 at 07:04 point
Thank you very much Tom!
