Modular PCB origami
The unique design makes its assembly independent of frames or jigs. Use hardwires to connect a pair of PCB and fold it into the shape.
Starting from
has orders / reviews
Ships from
This PCB (FR4) origami is unusual. The unique design makes its assembly free of 3D-printed frames or jigs. Solder hardwires to connect a pair of PCB and fold it into the shape you want. Current module are equilateral triangles. Squares and pentagons are coming soon.
Check the intro video on my twitter, https://twitter.com/warmbit/status/1418678000824950788
2021July26
I have a rough idea of modular PCB (FR4) origami starting from early 2020. The very first thing is a modular origami.
  • New Triangle is here!
    warmbit • 09/01/2021 at 17:19 • 0 comments
    I am going to release this on Tindie this afternoon. With all edges trimmed and all LEDs preassembled, this triangle should remove a lot of tedious and laborious tasks to make a PCB origami, either 2D or 3D. Just simple through-hole soldering. Stay tuned!
  • FlexPCB as another way to connect
    warmbit • 08/18/2021 at 23:53 • 0 comments
    Here are some new FlexPCB received from OSHPark. This is another way to connect each module. It is easier to bend this than hardwires. But more expensive for sure. 120 in total.
  • Arrival of purple square and pentagon
    warmbit • 08/13/2021 at 23:22 • 0 comments
    Today I have got the square and pentagon for PCB origami. The size matches with the old triangles. They are bit small for the new triangle.
  • module size adjustment
    warmbit • 08/07/2021 at 15:23 • 0 comments
    I am making a bit bigger size of triangle. At the same time, the size of square, pentagon and hexagon is changed to be compatible with each other. This will take a longer time.
View all 4 project logs
  • 1
    How to build the DiscoBall from triangles?
    Here are major steps to build a DiscoBall from the triangle modules.
  • 2
    Trim the edges of each triangles.
    All the triangles comes with mouse bites in a panel. Trim the edge and make it smooth and even.
  • 3
    Solder LED to the top of each triangles
    These WS2812B-2020 LEDs are not that difficult to solder. The four pads are big enough for manual soldering.
View all 9 instructions
Artifex wrote 11/28/2022 at 04:54 • point
I notice that when connecting the triangles, not only are there wires soldered between the +, -, and data lines, but there seem to be little drops of solder near the edge on what looks like tiny touchpads or something. these seem to be on the output side and on + and - only. Can you explain what this is about?
