New Triangle is here!
09/01/2021 at 17:19 • 0 commentsI am going to release this on Tindie this afternoon. With all edges trimmed and all LEDs preassembled, this triangle should remove a lot of tedious and laborious tasks to make a PCB origami, either 2D or 3D. Just simple through-hole soldering. Stay tuned!
FlexPCB as another way to connect
08/18/2021 at 23:53 • 0 commentsHere are some new FlexPCB received from OSHPark. This is another way to connect each module. It is easier to bend this than hardwires. But more expensive for sure. 120 in total.
Arrival of purple square and pentagon
08/13/2021 at 23:22 • 0 commentsToday I have got the square and pentagon for PCB origami. The size matches with the old triangles. They are bit small for the new triangle.
module size adjustment
08/07/2021 at 15:23 • 0 commentsI am making a bit bigger size of triangle. At the same time, the size of square, pentagon and hexagon is changed to be compatible with each other. This will take a longer time.
