1How to build the DiscoBall from triangles?
Here are major steps to build a DiscoBall from the triangle modules.
2Trim the edges of each triangles.
All the triangles comes with mouse bites in a panel. Trim the edge and make it smooth and even.
3Solder LED to the top of each triangles
These WS2812B-2020 LEDs are not that difficult to solder. The four pads are big enough for manual soldering.
4Connect a pair of triangles with LED soldered - Tape
Tape a pair of triangles. The top side with LEDs is facing down. Three through-hole resistors are used here. Match the side with O (output) with the side of I (input). Square to square.
5Connect - solder and bend
These through-hole soldering is easy.
6Connect - cut the wires
Here you have to estimate of the cut.
7Connect - solder the other three.
Get the right triangle out and these wires into three via-holes of the right triangle, which is vertical. Now move the right triangle into the horizontal position and align it with the left triangle.
8Connect more triangles
9Connect all triangles and test them
warmbit
