joystick_checkpoint_1.FCStd
FreeCAD file - parts can be exported as STL if you want to print. Be aware tolerance on the parts are tight. If eg the breakout board for the mini stick is a bit different it will not fit...
x-zip-compressed -
424.94 kB -
08/23/2021 at 20:33
