Controller connectivity Issue
05/21/2023 at 15:41 • 0 commentsThe code is designed to allow wireless controllers to connect after powerup. This seems to work "most" of the time. Occasionally a wired controller is not detected on power up (stays in Connecting... state), but requires a reset before it connects. Needs further investigation.
Schematic Mod
05/21/2023 at 15:32 • 1 commentThis works just as well with a wired controller as it does with a wireless receiver module.
My wireless receiver died for some reason, hence the switch to wired controller until i get my hands on another one. As a precautionary measure I have introduced a 10Kohm pull up resistor to 3v3 for the incoming DATA line.
I will update the schematic to reflect this when I get a chance.
Source Code v1.10 avaialable
05/21/2023 at 15:22 • 0 commentsApologies, I started adding features (such as config menu, preset buttons, snoop mode etc),then life got in the way.
I have submitted my original source code v1.1 release to github:
Sept 21
09/04/2021 at 20:10 • 0 commentsSeems to be working well.
Finishing off the preset up/down clear/save code.
Need to tart up code for github.
deoscode
