1Cut four 12" rods into eight 6" rods
2Fasten the rods together into two rectangle frames (I used staples for quick & easy)
3Waterproof one of the frames fully (I laminated with packing tape)
4Secure screen to back of laminated frame
5Place copper plate on UNLAMINATED frame
6Fasten and seal the copper plate to the frame with high temperature tape
7Seal back of the plate to the frame so there are no gaps for water vapor or adsorpent to escape
8Add adsorpent - I use zeolite for fish tanks
9Attach and seal two frames together so the screen holds the adsorpent packed tightly (I used a generous amount of packing tape)
10Add insulating material around the outside. (I used mylar bubble-wrap from grocery delivery bags)
Step 13, where you connect the icing bag, is a little unclear to me. Are you placing the bag around the entire thing? How is it sealed?
