BADGE FOR SUPERCON.6 / November 2022
After three years... Supercon again!
And the new badge too!
YouTube video: https://youtu.be/ix__enrtYF4
4-bit processor simulated by 16-bit MCU. Registers, flags, ALU, SP, two Data Memory pages, current Program Word and some internal logic states are displayed in binary form, with 272 LEDs.
- A total of 31 instructions
- Processing speed: adjustable (in runtime) from 250,000 ips to 0.5 ips, plus Single Step
- Program Memory: 4096 pgm words × 12 bits
- Data Memory: 256 nibbles (32 visible in real time)
- 5-deep Subroutine Stack
- Opcodes/Operands are 4-bit aligned, visible on 3×16 LED disassembler display
- Three ways of programming:
1. Direct, using on-board buttons in Binary or Select mode
2. Indirect, using 2-pass assembler, created by Mike Szczys
3. Save/Load to/from computer or other badge (using serial I/O) or internal flash
- Bootloader for firmware update
- I/O port with 4-bit IN and 4-bit OUT
- 3V (2×AA) Battery supply
- SAO port with Serial I/O
- Detailed User Manual
- Dimensions 17.5×9.
Reflash to version Badge Berlin 2023.zip
Please download, unzip and read the attached .TXT file
x-zip-compressed - 10.75 kB - 04/28/2023 at 19:31
Download
- The new version of firmware, created in February 2023. - The year and v1r1 extension are generic, that`s why it's 2022 v1r1. - Contains new functions described in Manual Rev4a.pdf, and some minor bug fixes - This version of firmware was prepared for the Berlin conference, but due to a manufacturing error in China, the old version was programmed. - To open the project, install MPLAB X IDE - To program using MPLAB X IPE, use this file: \dist\default\production\Badge2022_v1r1.production.hex (the year and v1r1 extension are generic)
x-zip-compressed - 322.08 kB - 04/27/2023 at 18:14
Download
1 Manual Rev4a.pdf
User Interface, Commands and Modes of Operation
Adobe Portable Document Format - 1013.21 kB - 11/11/2022 at 20:45
Preview
2 Instruction Set Rev4.pdf
Detailed explanation of all instructions
Adobe Portable Document Format - 1.05 MB - 11/03/2022 at 02:25
Preview
3 SFR Rev4a.pdf
Special Function Registers. NOTE: Revision 4a (Nov.03.2022) contains an error fix (page 24, KeyReg). Please use this revision if you have Rev4 or lower.
Adobe Portable Document Format - 647.36 kB - 11/04/2022 at 03:07
Preview
View all 10 files
Rich text editor
Mohit Bhoite | मोहित भोईटे wrote 11/08/2022 at 19:30 point
@Voja Antonic
I can't imagine the amount of work you must have put into creating the user manuals and other documentation for this badge. They are all beautiful! I heard that you are using Corel Draw for creating these documentations, is that right? If so, what does that process look like? Are all the symbols created manually or is there a clipart library that you use for the schematics. How do you add junction symbols on the wires? manually?
Thanks!
Bob Long wrote 11/06/2022 at 23:37 point
For anyone making their own and wondering about LED orientation, I think it's anode (+) on the left and/or down for all of them. The pick-and-place file does not use cathode-left for zero-rotation. I had to check by importing the PCB into KiCAD, and then double checked by looking for a die in the high-res photos.
@Voja Antonic, could you please correct me if I am wrong? Would be good to get orientation information into the Placement.zip images
Voja Antonic wrote 11/07/2022 at 15:47 point
You are right about LED orientation, anode is always left, down or left-down. There's a marking which is invisible once it's not needed anymore, on the top silkscreen layer under the rightmost button. Enlarge the last (6th) image in the project gallery and note the yellow symbols at the bottom right. There's a number of LEDs (272) and orientation.
Bob Long wrote 11/07/2022 at 15:54 point
Ah, that's a great silkscreen indicator! I missed that. Thank you!
James Newton wrote 11/06/2022 at 17:18 point
@Voja Antonic May I humbly suggest that you edit the description to link the text
"assembler, created by Mike Szczys"
In the description to the repo at:
https://github.com/Hack-a-Day/2022-Supercon6-Badge-Tools
TomKeddie wrote 11/05/2022 at 03:41 point
@Voja Antonic the files for my East Van addon board are at https://github.com/TomKeddie/prj-supercon2022/raw/12320199498d3a410aec8e213062e2ced3b3eca3/badge/Supercon%202022%20East%20Van%20Badge%20Addon%20Schematic.pdf and https://github.com/TomKeddie/prj-supercon2022/raw/main/badge/Supercon%202022%20East%20Van%20Badge%20Addon.pdf
Thanks for all your hard work.
cgeron wrote 11/04/2022 at 22:30 point
@Voja Antonic where can the challenge be found?
Voja Antonic wrote 11/05/2022 at 01:19 point
*  *  *  *  Here's the challenge:  *  *  *  *
You have to write the shortest possible program which does this:
- Load two random nibbles (see the 3.SFR manual page 26) in two registers, and
- Calculate the Parity bit for these 8 random bits.
So the result should be a single bit which tells you if the parity is even or odd. The program should be optimized so that it contains as few words as possible.
Please submit your solution here in the discussion group. The shortest program wins. If two or more programs have the same length, then the time of submission counts.
cgeron wrote 11/05/2022 at 05:42 point
9 lines is (I think) the smallest it can be made, if we make the assumption that the badge is in the state it is found in after a reset (input pins are pulled up, so special purpose register B on page 0 is all 1's). The result is found in the LSB of R1:
-  | Text                 |Instruction binary |Comments
0 | MOV R2,4      | 1001 0010 0100    |Counter for later
1  | MOV R0,[BB]  | 1011 1011 1011          |*Retrieve Rnd to R0
2 | MOV R1,R0     | 1000 0001 0000  |R1<-R0
3 | MOV R0,[BB]  | 1011 1011 1011          |*Retrieve Rnd to R0
   |Loop time
4  | XOR R1,R0     | 0111 0001 0000    |XOR R1 and R0, result in R1
5  | MOV R0,R1    | 1000 0000 0001  |Copy the result of the previous step to R0
6  | RRC R0          | 0000 1101 0000   |Shift R0 to the right
7  | DSZ R2          | 0000 0100 0010  |Decrement R2(counter) and check if 0
8  | JR -5              | 1111 1111 1011             |Jump relative -5
*Retrieving the Rnd register cannot be done by using MOV R0,[FF] because as specified in page 15 of the insruction set, MOV R0,[XY] requires indirect addressing with registers RX and RY. For this, register B was used since it is normally used as an input port register and is nominally pulled up. This code would still work with a single difference if register B cannot be assumed as 1's: an instruction would be added to the start to set R3 to 1111, and then the instructions currently on lines 1 and 3 would become "MOV R0[R3,R3]". Using register B is hacky...but that's the point :)
TheStumbler wrote 11/04/2022 at 05:08 point
also the parts placement diagram shows two each 10 uF caps, the second one not on the schematic but connected to the power pins of the two two ICs (shift registers?)
Voja Antonic wrote 11/04/2022 at 05:58 point
It's the power supply decoupling cap. There was an error on the schematics, please download the new version of the Hardware Rev4b.pdf
Two ICs are decoders 74HC138 (3-to-8 lines)
TheStumbler wrote 11/04/2022 at 05:05 point
How critical is the Vcap 10 uF capacitor in this design? The data sheet has some specific requirements for it but I’m not 100% sure it applies to this circuit board.
Voja Antonic wrote 11/04/2022 at 06:03 point
Very critical. It is a low-ESR capacitor, used to stabilize the MCU's internal 1.8 V regulator voltage for the processor's core.
TheStumbler wrote 11/04/2022 at 06:06 point
oh. Then I’m dead I the water. I didn’t appreciate that critical part and didn’t order any. Looks like I don’t have anything close in my parts bins either. Oh well, another DK order and one more week. Looks like I’ll miss having it running at the same time as the conference is going on
Voja Antonic wrote 11/04/2022 at 06:15 point
It's interesting that Microchip suggests that the distance between the MCU "Vcap" pin and the cap terminals should not exceed 0.25 inch (6 mm).
Voja Antonic wrote 11/04/2022 at 06:21 point
Also, if you order it, note that it should be rated for 16 or 25V, although it works at 1.8V only. It is surely because of its dynamic characteristics.
TheStumbler wrote 11/04/2022 at 20:38 point
oh. I just realized. I may be lucky. I have a couple of boards which use Microchip SAM processors and I might be able to steal a 10uF cap temporarily from one of them. Maybe
Octavian Voicu wrote 11/03/2022 at 00:08 point
Can the Overflow flag be accessed by the program in any way, or is it just for debugging in single stepping mode? No instruction's output (including SKIP) depends on it and the flags seem to be internal to the ALU (not in user mem like other registers).
Voja Antonic wrote 11/03/2022 at 02:47 point
Overflow flag is accessible in the Special Function Registers area, at the address 0xF4 (RdFlags), bit 1.
To let this flag affect the program flow, you can load RO with this register and then test bit 1 in R0, for instance...
1101 1111 0100         MOV R0, [0xF4]     ;  R0  <----  [RdFlags]
0000 1001 0001   BIT    R0, 1              ;  Z  <----  Vflag
0000 1111 1110        SKIP  NZ, 2            ;  Skip next 2 instructions if NZ
... next 2 instructions could be an absolute jump, like MOV PC, NN and MOV PCL, N
SHAOS wrote 11/03/2022 at 03:32 point
In my "unofficial" assembler RASM this code may look like this :)
@RDFLAGS EQU #F4
LABEL:
    LR0 @RDFLAGS    // R0  <----  [RdFlags]
    BIT_R0, 1    // Z  <----  Vflag
    SKIP_NZ,2    // Skip next 2 instructions if NZ
    JMP    LABEL    // an absolute jump, like MOV PC, NN and MOV PCL, N
and it will be assembled to this:
 000 0D LABEL:    LR0 @RDFLAGS    // R0  <----  [RdFlags]
     F4
 001 00        BIT_R0, 1    // Z  <----  Vflag
     91
 002 00        SKIP_NZ,2    // Skip next 2 instructions if NZ
     FE
 003 0E        JMP    LABEL    // an absolute jump, like MOV PC, NN and MOV PCL, N
     00
 004 09
     D0
Voja Antonic wrote 11/03/2022 at 03:38 point
Looks good.
I am so sorry that I couldn't try your assembler. Surely due to my inexperience with using GitHub repos. It seems that I'm not a good team worker :)
SHAOS wrote 11/03/2022 at 03:49 point
I'm pretty sure that "official" assembler is gonna be much prettier, but because it is not yet available I'm offering my "quick & dirty" solution to the public :)
I can build DOS binaries or MAC binaries or whatever binaries of RASM if anybody needs some ;)
Voja Antonic wrote 11/03/2022 at 03:59 point
I'm not sure that I could name it "official" assembler. It was written about two years ago by Mike Szczys and it works very good, but it must run under Python, which will probably limit a number of users.
I guess that it depends on the ease of application. There are people (like me) who are kind of "autistic" to some forms of interactions with the computer :(
SHAOS wrote 11/03/2022 at 04:02 point
Moreover "official" tools require Python 3.6+ as I heard which should limit number of users even more...
Octavian Voicu wrote 11/03/2022 at 14:04 point
Thanks, I missed that!
Octavian Voicu wrote 11/03/2022 at 14:24 point
A couple more questions related to the V flag:
- In the Instruction Set doc, the table on page 2, both CP R0,N and ADD R0,N are shown to affect the V flag (and this makes sense, since they're similar to ADD and SUB). However, in the Flags affected subsection for each instruction, the effect on the V flag is not documented. Is it just same as ADD/SUB?
- What about INC and DEC, do they affect the V flag? (not documented, so just checking).
Hint: I'm working on an emulator, hope to have something working today :)
SHAOS wrote 11/04/2022 at 03:43 point
One more Emulator? Great :)
Andy Geppert wrote 11/01/2022 at 17:44 point
If you think like I do... you'll appreciate page numbers added to the badge manuals. You can download them here: https://www.dropbox.com/sh/t0uu3ys5mftlv66/AAC3MJ9OSTowr2Yq4cLf6Jh1a?dl=0
Voja Antonic wrote 11/02/2022 at 17:12 point
I agree and I hope that I'll have enough time to do it before the Supercon. Unfortunately, manuals were written in CorelDraw, so I have either to do it manually for every page or to reformat PDF pages for every new revision.
Thanks!
Voja Antonic wrote 11/03/2022 at 02:49 point
Done. Revision 4 contains page numbers.
SHAOS wrote 10/30/2022 at 11:25 point
My "unofficial" assembler is released: https://hackaday.io/project/158426
Now I'm going to create a number of sample programs and may be emulator ;)
Stefano wrote 10/27/2022 at 19:04 point
There are example programs?
Voja Antonic wrote 10/28/2022 at 00:28 point
At this moment, there are only two sample pre-loaded programs with the code that can be regularly edited, ran in different speeds or single-stepped. One of them simulates the moving message display with Shakespeare's Hamlet :) and another one is used for Serial In demonstration, with UART_ASCII-to-text conversion.
However, all subsequently written programs will be exchangeable via Internet and up/downloadable via Serial port. The same applies to the main firmware, which can be bootloaded in case the new version appears.
SimonGurney wrote 10/27/2022 at 18:29 point
Any chance of buying one of these?  I'm in the UK and have no chance of getting out to SuperCon 😭
Voja Antonic wrote 10/28/2022 at 00:16 point
I'm not sure. Knowing the production process, there will hardly be any leftovers and subsequent sales were not planned.
TheStumbler wrote 10/27/2022 at 12:57 point
where’d you get the PIC24F256 chips? I just got all the parts and the PCB. But I can’t find the PIC anywhere.
Voja Antonic wrote 10/28/2022 at 00:12 point
The prototypes were built more than 2.5 years ago, when MCUs were regularly available, and we were careful enough to order the production batch directly from Microchip in the spring this year.
I checked and Microchip estimates that 24,320 pieces are going to be available on 19-Dec-2022. Price is $2.05 for quantities 1 to 24. However, I'm not sure that you can order a small quantity, as they gave prices for 1-24 and 25-99 pieces, but then they used the order form with a note "Multiples of 160". Please check it here:
https://www.microchipdirect.com/product/PIC24FJ256GA704-I/PT?productLoaded=true
SHAOS wrote 10/26/2022 at 05:12 point
I'm currently working on assembler for this CPU under my nedoPC SDK project: https://hackaday.io/project/158426-nedopc-sdk
Voja Antonic wrote 10/26/2022 at 05:18 point
Good luck!
Is it going to be two-pass assembler, with labels?
SHAOS wrote 10/26/2022 at 05:22 point
Of course :)
With relative short jumps and "synthesized" long jumps to labels (no numbers needed)
Voja Antonic wrote 10/26/2022 at 05:35 point
Wow...
It could be useful if it generates binary file, so that it can be downloaded and directly executed. File format is described in the main manual, chapter Dir Mode, buttons Save and Load. Here's the file form (Little Endian, bits 15-12 in program body are all zeros):
1. Header, 6 bytes: 00 FF 00 FF A5 C3
2. Program length, 2 bytes (in 16-bit words, Low byte first): NN NN
3. Program, NN 0N×Program Length (Low first): NN 0N, NN 0N, NN 0N...
4. 16-bit Checksum for items 2 and 3 only, 2 bytes (Low first): NN NN
SHAOS wrote 10/26/2022 at 05:36 point
Yes, my assembler RASM in this case generates binary in big-endian format (higher byte 1st, lower byte 2nd), so it has to be extra utility to convert this binary to little-endian format with header and checksum as described above (or it will be specifically written command line program that will take big-endian binary produced by RASM to send it in proper way over serial port swapping bytes on the fly).
Voja Antonic wrote 10/26/2022 at 05:42 point
Sounds good!
There will be at least one more assembler, created by Mike Szczys, as it was noted in the project description. This one is executable under Python environment only.
SHAOS wrote 10/26/2022 at 05:45 point
I think in discord somebody wrote that there are more than one assembler already and it's still discussed which one will be released as "official" ;)
If "official" assembler will be in Python then mine will be fastest ;)
And more portable - my RASM is compiled by any 16-bit, 32-bit or 64-bit ANSI-C compiler ( I started working on this universal assembler in January 1997 under MS-DOS 6.22 using Borland-C++ 3.1 : )
Voja Antonic wrote 10/26/2022 at 05:51 point
One thing is for sure: none of them will be mine. Actually, the only programming language that I use is assembler for embedded systems. I'm totally inexperienced with system or application programming.
sphereinabox wrote 10/25/2022 at 15:29 point
I'm going through the instruction manual and found a few typos on pages 1-15 so far. Sorry for the tiny blurry screenshot I somehow can't print/export the annotations. Mostly found numbers that are wrong given the rest of the context, and a few places where you call out registers by one name but label them with another (R10/OUT for example).
https://imgur.com/a/aiCoEEp
Voja Antonic wrote 10/25/2022 at 16:16 point
You are a very careful reader and this was a huge help for me. All typos were corrected and they will appear in the new revision soon.
However, all the register numbers/symbols were left as-is. The examples for all instructions were given in the same way as they are "typed" in the "button interface" - with literal integers, and register tables in the same way as they are represented on the silkscreen table - with register symbols. It's also a good chance for a reader to become familiar with register symbol names.
Thanks, nwinters3000! Please let me know if you spot more errors. I worked alone on these extensive manuals and you probably know how hard it is to locate your own error.
sphereinabox wrote 10/26/2022 at 15:48 point
@Voja Antonic p19 JR NN thew new program memory address bits are wrong, still are 65 not 62. p23 DEC RY flags instructions say C should be set when result is 1111 but graphic shows C being reset. p26 AND R0,N sample opcode text is AND R0,6 but bits and rest of example are AND R0,*10*.
I like the IOPOS=0/IOPOS=1 annotations on the arrows on page 30 BIT RG,M. Please copy them to the following pages.
page 36 BTG RG,M example 2 has dashed arrow going from 0xFA into zoom bubble, but it should be coming from 0x0A instead if the switch and numbers are correct.
I haven't looked in the other manuals in as much detail yet, but I think the "Manual" document should move the "Programmers model" section much earlier, probably even before explaining the all the buttons, connectors, and instruction decoder. At least the first page of this section serves as an introduction that gives the rest context. Or maybe there's a more introductory document people should read first?
Anyway I've been finding issues by going through and implementing the instructions in javascript. https://github.com/sphereinabox/had-badge2020-22-websim
Voja Antonic wrote 10/26/2022 at 16:21 point
Fixed, thanks. A new revision will be released soon. I moved the Programmer's Model pages too.
sphereinabox wrote 10/30/2022 at 18:27 point
SFR Rev3.pdf
 - p12 calls 0xF1 "Clock" but p10 calls it "Speed"
 - near the end of the description text on p17 it calls out register pair "SFR7". It should be "SFRF7"
 - p20 suggests AutoOff gets set to 1111 on every keypress. I assume you mean "your code might set it to 1111 for example on every keypress" as described in the text
 - p25 SFRFE could use a bit more detail. Is 15 "most bright"? Does 0 mean "most dim" or "off".
Is the V flag set by add/sub instructions the one at F4 bit at mask 0b0010? p31 of the manual rev3 suggests it's not memory mapped, like PC, V, C, SP, HP, Mode are not memory mapped. Do the C and Z flags show up in the memory map? I'm guessing maybe V is memory mapped because unlike C and Z it's not used by any instructions.
The initial state of some memory isn't documented:
 - SFRF4 (RdFlags)
 - SFRF6 (SerLow)
 - SFRF7 (SerHigh)
 - SFRF8 (Received)
Voja Antonic wrote 10/31/2022 at 00:00 point
Fixed. Thanks, nwinters3000.
However, AutoOff register is automatically preset to 1111 at every keypress. The suggestion to write 1111 in the program is valid only if you want to protect your badge from unwanted automatic turning off.
Yes, V flag is memory mapped as bit 1 in memory location 0xF4.
SHAOS wrote 10/24/2022 at 03:43 point
Few questions:
1) is anybody writing tetris for this badge?
2) is anybody working on high-level programming language compiler for this badge?
Asking for a friend ;)
Voja Antonic wrote 10/24/2022 at 03:58 point
1) No, as far as I know
2) No, as far as I know
May I ask a question too?
3) Will someone write Game of Life on hacking night?
SHAOS wrote 10/24/2022 at 04:08 point
What is "hacking night"?
Voja Antonic wrote 10/24/2022 at 04:26 point
Well, maybe not night, more like evening. When all hackers show what they can do with the badge.
SHAOS wrote 10/24/2022 at 04:36 point
Ok, may be somebody will present GoL in the last moment ;)
Jacob Still wrote 10/24/2022 at 05:41 point
I am planning on presenting GoL.
Ryan Steele λ wrote 11/09/2022 at 21:35 point
@Voja Antonic ,
@Jacob Still and I worked on Game of Life. I mean, I finished it like 5 days too late, but here it is...
https://github.com/jcstill/supercon_2022/blob/master/programs/04_conway/04_conway.asm
SHAOS wrote 10/21/2022 at 05:22 point
Reading docs - I think I finally understood how to call subroutine (by setting PCH,PCM by MOV PC,NN instruction and then writing to JSR), but how can we RETURN from subroutine?
Ok, nevermind - it's RET R0,N instruction...
Voja Antonic wrote 10/21/2022 at 05:27 point
Just execute instruction RET R0,N at the end of the subroutine.
In many cases N (integer 0-15) will be dummy argument which does nothing except destroying R0 register, but it is useful if you have to create lookup table.
SHAOS wrote 10/21/2022 at 05:39 point
Actually I think it's a great side-effect that allows to do 2 actions at once :)
SHAOS wrote 10/22/2022 at 02:13 point
Another question - it looks like writing to PCL, PCM or PCH immediately initiates jump to combined new address - right? But MOV PC,NN doesn't do that, correct? It just sets PCM and PCH for subsequent write to PCL (or JSR) and only then it's doing the jump.
Voja Antonic wrote 10/22/2022 at 02:27 point
Writing to PCM, PCH or using MOV PC,NN does not initiate jump. Only writing to PCL or to JSR causes automatic Jump or Call.
Please note that only instructions MOV RX,RY, MOV RX,N and INC/DEC RY initiate jump or subroutine call. Modifying or writing to PCL or JSR by any other instruction is treated as the simple memory modify or write.
SHAOS wrote 10/22/2022 at 03:13 point
ok, makes sense - then docs need to be corrected - "3 SFR Rev2a.pdf" pages 8 and 9 say in "Operation" paragraph: "However, this register will take action when program jump (writing to PCH) or subroutine call (writing to JSR) occurs." So here it has to be "writing to PCL" instead of PCH (and instead of PCM on previous page).
Voja Antonic wrote 10/22/2022 at 03:56 point
Corrected.
Thanks!
Nazwa wrote 10/20/2022 at 17:34 point
I need translate this to Polish lang
morgan wrote 10/20/2022 at 17:22 point
Hi @Voja Antonic can you enable public chat so we have a good place to discuss badge hacking?
Nazwa wrote 10/20/2022 at 18:23 point
discord or irc
SHAOS wrote 10/21/2022 at 05:23 point
or supercon-2022 chat ;)
Voja Antonic wrote 10/21/2022 at 05:39 point
It's a good idea. I'll do something about it.
gatin00b wrote 10/19/2022 at 14:51 point
Hi, in RET instruction description the pseudo-code updates R0 with PC instead of N as described in the test.
gatin00b wrote 10/19/2022 at 15:00 point
Also, address calculation to retrieve the return address would be wrong since SP would be off by one before it is decremented.
Voja Antonic wrote 10/19/2022 at 15:08 point
You're right with your first post, gatin00b. Thanks!
It's corrected and will be visible in the next version, in a few days.
Voja Antonic wrote 10/21/2022 at 05:38 point
I don't think that there's an error here. SP always addresses the NEXT address field for return, not the current one.
gatin00b wrote 10/21/2022 at 17:15 point
Maybe I'm just reading this bad, but the Operation section of RET instruction in instruction manual mismatches the behaviour described in the User Manual.
Voja Antonic wrote 10/21/2022 at 17:34 point
You are right! The order of operations in the Instruction Set book was wrong. Thanks for being persistent, this helps a lot!
Somehow I managed to pack two errors in a single statement :)
So the correct operation should be:
(R0) ← N
SP ← SP-1
PC <11...0> ← ((SP×3+2), (SP×3+1), (SP×3))
Thanks!
