Component side of the strip board
JPEG Image -
253.15 kB -
01/12/2022 at 22:49
Preview
Veroboard, showing tracks to be removed and holes to be drilled
JPEG Image -
186.61 kB -
12/31/2021 at 00:57
Preview
Vario_Customisation.pdf
Instructions for installing a PC terminal program, connecting the Vario and modifying the stock configuration sensitivity and excitability level.
Adobe Portable Document Format -
469.53 kB -
12/30/2021 at 22:26
Preview
VARIO_BOX.stl
3D print STL file for enclosure parts as single file (you may need to separate the parts to print individually.
Standard Tesselated Geometry -
584.26 kB -
12/30/2021 at 22:16
Download
Schematic for the variometer
JPEG Image -
102.12 kB -
12/30/2021 at 22:04
Preview
AUDIO_VARIOMETER_SOURCE.zip
Arduino IDE code for the variometer
x-zip-compressed -
6.88 kB -
12/30/2021 at 22:03
Download
