Raspberry Pi Zero 2 W Active Cooling
Active cooling and power breakout board for RPi Zero 2 W
This project was born out of a necessity for active cooling on a Pi Zero 2 W I'm using to create a DIFFERENT Project, I'm tentatively calling the "Secure Frame", an open source photo frame kit that can interface with Dropbox, Owncloud, or just local NAS storage instead of being tethered to a service that's not guaranteed to last longer than 2 -3 years.
I was noting that the Pi Z2w was getting hot, REALLY hot, since the processor was constantly in use to drive the graphics output, something the PiZ2w probably wasn't quite designed for. Adding heat sinks only got me so far, and that's when I realized I needed to add in active cooling.
Since I haven't actually designed a board in a while, especially in Eagle, this was really fun and frustrating, trying to get the layout just right, which I feel like I did, for this project.
BE_SecureFrame.brd
Board Layout file for the power and fan board
brd - 24.83 kB - 01/14/2022 at 00:51
Download
BE_SecureFrame.sch
Eagle Schematic file
sch - 21.37 kB - 01/14/2022 at 00:51
Download
tyler wrote 01/14/2022 at 19:48 point
Does that schematic have the fan connector labeled for 3A / 250V? If it were, I think this would introduce more heat issues than it solves :)
tyler wrote 01/14/2022 at 19:50 point
On second thought, that could be a max rating for the part... pls let me know if im wrong ;]
peter.beal wrote 01/14/2022 at 22:38 point
Correct, that's just the max rating for the JST socket connector.
