1Order Parts
- Download the BOM
- Import the BOM to digikey
- Replace components if necassary (but double check footprints etc)
- This BOM excludes the WS2812, this is only needed for testing
- Order the WS2812 strip
2Order PCB
- Download the gerber files
- Go to JLCPCB => order now
- Drag zip file into dropbox
3Programming MCU (w/ Arduino ISP)
- See this tutorial for setup
- Warning: DIP switch should be off during programming
- Insert widget pins into pins (10->13) of arduino uno
- Be sure to line up the GND pins, all other SPI pins will then be lined up correctly
- Download the C code, and import into arduino ide
