M5Pi is an open source Linux embedded development board, using Allwinner F1C200s CPU, and has a beautiful shell.
M5Pi-R4.0-KiCad.zipPCB design filesZip Archive - 1.52 MB - 01/26/2022 at 08:25 |
I tried to open the design files on KiCad 6 but got errors. What version of KiCAD should I use?
See the warning on this page: https://github.com/imliubo/M5Pi/tree/main/Hardware
you can use this website for youtube downloading. https://easysave.net/ytmp4/
So they copy M5Stack case design and make Pi version of it. Nice! Maybe it is M5stack module compatible also
Yes, the pin map compatible with M5Stack Modules, also support UNIT-x serials sensors.
Have you plans to put this sell? At least that case is quite hard to get at small amounts
F1C200s perform is not very powerful so this is will not sell, actually I'm designing new board, much powerful than this one :)
ok, you may run to thermal issues with H3-H7 allwinners ;) What plans you have for case? It is not quite usefull if we need disassemble m5stack just for get case from it :D
is possible add step up -down from 0-24V power input?
in many situation i can use many different power, meybe solar panel meybe AA 1.5V or .. 18650 3.7V or car power 24V
how long this device work ? for example 50% vi/mc/terminal and 50% listen sound in background or compiling/using ruby/perl/go
