M5Pi
M5Pi is an open source Linux embedded development board, using Allwinner F1C200s CPU, and has a beautiful shell.
The M5Pi is an embedded Linux development board that I made and open sourced last year. It is based on the F1C200s chip of Allwinner Technology, the most important thing is to have a beautiful casing, which is why I call it the most exquisite "Pi", the project is completely open source, the open source software used for PCB KiCAD drawing, some 3D models use the open source software FreeCAD to draw, the system uses the more popular buildroot to make.
https://github.com/imliubo/M5Pi
https://www.youtube.com/watch?v=1ejPf3YfseI
Thanks to the sponsor Seeed!
Seeed Fusion PCB Assembly Service offers one-stop prototyping for PCB manufacture, PCB assembly and as a result they produce superior quality PCBs and Fast Turnkey PCBA from 7 working days. When you prototype with Seeed Fusion, they can definitely provide Free DFA and Free functional tests for you! Check out their website to know more: https://www.seeedstudio.com/prototype-pcb-assembly.html
M5Pi-R4.0-KiCad.zip
PCB design files
Zip Archive - 1.52 MB - 01/26/2022 at 08:25
Download
teraz wrote 08/24/2022 at 14:09 point
is possible add step up -down from 0-24V power input?
in many situation i can use many different power, meybe solar panel meybe AA 1.5V or .. 18650 3.7V or car power 24V
how long this device work ? for example 50% vi/mc/terminal and 50% listen sound in background or compiling/using ruby/perl/go
DumTux wrote 07/16/2022 at 00:17 point
I tried to open the design files on KiCad 6 but got errors. What version of KiCAD should I use?
Ken Yap wrote 07/16/2022 at 00:33 point
See the warning on this page: https://github.com/imliubo/M5Pi/tree/main/Hardware
nandalabuilder wrote 05/10/2022 at 10:41 point
you can use this website for youtube downloading. https://easysave.net/ytmp4/
singhm081085 wrote 02/06/2022 at 05:02 point
looks adorable lol.
IAMLIUBO wrote 02/08/2022 at 01:37 point
burner wrote 02/03/2022 at 18:25 point
So they copy M5Stack case design and make Pi version of it. Nice! Maybe it is M5stack module compatible also
IAMLIUBO wrote 02/08/2022 at 01:40 point
Yes, the pin map compatible with M5Stack Modules, also support UNIT-x serials sensors.
burner wrote 02/14/2022 at 15:49 point
Have you plans to put this sell? At least that case is quite hard to get at small amounts
IAMLIUBO wrote 02/15/2022 at 04:11 point
F1C200s perform is not very powerful so this is will not sell, actually I'm designing new board, much powerful than this one :)
burner wrote 02/15/2022 at 08:25 point
ok, you may run to thermal issues with H3-H7 allwinners ;) What plans you have for case? It is not quite usefull if we need disassemble m5stack just for get case from it :D
