SludgeCo [gd0016]
Air purifiers for my war against dust.
Public Chat
0 followers
This project is an aim to monitor and purify the air using a fleet of mini air purifiers with the most sensors as my budget allows.
Essentially superseded by #TrueTent TempLab [gd0143] when I found out just how much airflow and activated carbon is actually need to keep a room filtered.
  • [A] Initial Project Status
    kelvinA05/26/2022 at 21:27 0 comments
    I conceptualised this project probably years ago at this point. I did quite a bit of research on air particle detectors and what sensors give readings that would be benificial to me, such as a sensor that detects when the air is stale.
    For air purifying, I wanted to try a more decenteralized approach to improve filtration speed and air circulation. Thus, I'm thinking of a few of these which all charge on a docking station.
    Here's a render of the idea which I created moments ago:
    I'm trying out DOF in Fusion 360's rendere for the first time.
    This wasn't the first idea I came up with. The first one looked like the grey section expanded all the way to the inner corners of the white brackets, and that said grey section was black.
View project log
