THIS IS A WORK IN PROGRESS PROTOTYPE
PLEASE USE AS A REFERENCE ONLY
Total US$1000
ML5010 (gogo-rc) $29 x 12 = $360
6701 ZZ or RS Bearing (AliExpress "Hardware appliances") $0.25 x 16 = $4
6704 ZZ or RS Bearing (AliExpress "Hardware appliances") $0.65 x 20 = $13
6807RS $1.5 x 12 = $18
6809RS $1.75 x 4 = $7
6810RS $3.75 X 4 = $15
225-3M-06 (182-1302 RS-Components) Timing Belt $4.25 x 4 = $17
201-3M-06 (182-1298 RS- Components) Timing Belt $4.00 x 8 = $32
300-5M-09 (175-5197 RS-Components) Timing Belt $4.75 x 8 = $38
265-5M-09 (175-5193 RS-Components) Timing Belt $5.25 x 4 $21
6mm x 2dia Diametric Magnet (93201 AMF Magnetics) $0.65 x 12 = $8
500mm 20x10 Al Extrusion (Bunnings) $4.00 x 0.5 = $2
Total Electro-mechanical $535
Custom Controllers ESP32-WROOM $35 x 12 = 480
Plus Batteries and a Brain/Sensors
Swaleh Owais
Alexis
Guis
How far did this project get? The last comments here are from 2022. I built something like this but found out the cheap motors used were not nearly good enough, and guesstimated I would need the motor you bought. In fact, I have one motor on the test stand. Did it work well enough for your 8Kg robot?
