Revision of Bus Architecture for A1
04/07/2022 at 15:40 • 0 commentsBus Architecture for A1 v0.5 The previous bus architecture turned out to be too complex to implement on breadboard. So here comes the new version. The microcode set would be updated later on.
Microcode Design in Progress for A1 with a Newly Modified Bus Architecture
03/16/2022 at 09:58 • 0 commentsThe targeted decoding ROM is going to have 8-bit output. Under such restriction, the number of microcodes has to be not grater than 2^8 = 256 = 16 x 16.
Operation / Data Flow Coding Space Comment B < B1 < Bus-C < Reg
B > B0 > Bus-B > Reg2 x 16 Totally 16 registers in reg-file A1 < Bus-C < Reg
A0 < Bus-C < Reg2 x 16 B < ALU < Bus-A < A1A0 2 x 16 74LS181 has 5 lines selecting
2 modes by 16 functionsPC1 < Bus-C < Reg1
PC0 < Bus-C < Reg01 x 16 PC1 may only be loaded with
odd numbered registers. 1 x 8
PC0 may only be loaded with
even numbered registers. 1 x 8PC1 > Bus-A > ALU > B >> Reg1
PC0 > Bus-A > ALU > B >> Reg01 x 16 MEM < Bus-C < Reg
MEM > Bus-B > Reg2 x 16 C1C0 < Bus-C < Reg 1 x 16 D1D0 > Bus-B > Reg 1 x 16 SL(B)1
SL(B)0
SR(B)1
SR(B)04 Shift Left (B) one bit and fill 1
Shift Left (B) one bit and fill 0
Shift Right (B) one bit and fill 1
Shift Right (B) one bit and fill 00(ALU) > B1 > Bus-C > MEM
1(ALU) > B1 > Bus-C > MEM
0(ALU) > B1 > Bus-C > C1C0
1(ALU) > B1 > Bus-C > C1C04 All bits with 0
All bits with 1
Generated by ALU 74LS181C1 > D1
C0 > D0
C1 > D0
C0 > D14 IO < C1
IO < C0
IO > D1
IO > D04 IMM > D0
IMM > D12 IMM > IO 1 0(ALU) > B > Bus-B > CycleCounter 1 Reset CycleCounter to 0 StatusFlag < Bus-B < B0 < B 1 IR < Bus-B < MEM 1 Fetch instruction from memory A++ 1 32-bit {A1, A0} increase by 1 PC++ 1 32-bit {PC1, PC0} increase by 1 number of microcodes in total 216 = 6 x 2 x 16 + 4 x 4 + 2 + 6 An extra "SILENT" operation, to silent all buses and control lines, with the ClockCounter still working increasing, might also need be coded.
The bus architure has been modified again to make coding in 16x16 feasible. Also smaller number of ICs is preferred.
Fig. Bus Architecture v3 for A1 -
Design Progress in Bus Architecture for A1
03/12/2022 at 18:59 • 0 commentsWith just a flash in mind, being not a professional and starting from zero, after 3 weeks of search and learn, the bus architecture design for A1 finally came out.
At the very first beginning, project AOZORA was targeted to implement the Ibex RISC-V RV32EC core with mainly 74-series TTL ICs on solderless breadboards.
After reading project Pineapple ONE, support for RV32EC was abandoned, since a 32-bit computer requires a lot more ICs than a 16-bit or 8bit computer, as well as the 32-bit bus might be too wide to implement on breadboards.
Data bus width was finally decided to be 16-bit, and address bus to be 32-bit.
First version of the bus architecture design for A1 is mainly inspired by the famous 6502, and was hugely influenced by load-store architecture commonly seen in RISC architectures.
Fig.1: Bus Architecture for A1, version 1 Just one day after the bus architecture idea on paper has been redrawn with software, when reading amazing home-brew computer projects on Hackaday, 2-Zons' project 8 Bit Breadboard CPU showed at SIMILAR PROJECTS.
After looking into the block diagram of that project, it is clear that A1 shares a very similar bus architecture with that project.
So the bus architecture for A1 got some refinement inspired by that project and thus comes the second version.
Fig.2: Bus Architecture for A1, version 2 Bus architecture design is now almost complete, though a comparator might be needed alongside the ALU and the address decoder might also need design in detail. Focus will be put on designing controller unit and instruction set then.
