Bicopter V3
Design Bicopter frame easy to assemble yet strong enough to handle the component weight.
Public Chat
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
This project is inspired by the Bicopter V2 project https://hackaday.io/project/11752-bi-copter-v2.
I have designed this project in Solidworks. This frame is designed to support standard components available in the market, like blue SG90 servo and Yello A2212 BLDC motors. I have also designed some mods for this frame like off-center arms to heightened motors.
3D models can be found at
https://cults3d.com/en/3d-model/gadget/bicoper-v3-stl-and-laser-cutting-files
https://cults3d.com/en/3d-model/tool/bicopter-3d-laser-cut
[*] Design a 3d model
[*] Design Laser cutting files DXF
[ ] Lase cut parts
[ ] Assemble parts
[ ] Add electronics
[ ] Ground test
[ ] Publish project result
*The project is under development and actual hardware testing.
