- Started modelling the idea with some conservative estimates of needing 70mm on each side of the build volume and 60-70mm between each resin cartridge.
- I had a more slope-like idea for the base, but I decided on going flat to increase build volume.
- The XYZ is 860x500x1220mm.
- I was planning on having a top and bottom tank for cleaning fluid until I found out how tall this concept build was. The top tank will be moved to the back.
- A dishwasher-style door may be more suitable than the one I've modelled here.
- I don't know where the touchscreen would be mounted yet as the printer is larger than expected.
- The build height could be as much as 500mm with this design, due to the cartridge racks being so tall.
