All-In-One Gamma-Ray Spectrometer
Back to overview
More sensitive to gamma radiation than a Geiger counter with the added bonus of telling exactly what's inside your samples!
Rich text editor
gary.gonnella wrote 12/25/2022 at 20:06 point
Well I appear to have it running and getting some readings. I want to post some spectrums, where is the correct place to post?
NuclearPhoenix wrote 12/25/2022 at 20:34 point
I don't have a forum or something link that, but I think GitHub Discussions would be a good place: https://github.com/Open-Gamma-Project/Open-Gamma-Detector/discussions
gary.gonnella wrote 12/19/2022 at 19:03 point
I have the 30035 chip and I am ready to start assembly. I plan on putting 4 small pads of copper tape on a small piece of proto board and solder to the tape for stability and a way to bring the wires out.. On the optional SiPM board there are 2 resistors and 2 caps, are these only for power decoupling and are they necessary? With engineering school over 50 years ago things are pretty rusty in the old brain box but I am confident I can complete this project. Thanks for all the help.
NuclearPhoenix wrote 12/19/2022 at 19:29 point
Sounds good! You don't need the additional passive components. It'll work just fine if you keep all the connections as short as possible.
gary.gonnella wrote 12/18/2022 at 18:49 point
Now I am searching for the MICROFC-60035-SMT-TR chip and everyone is out of stock. I have found the MICROFC-30035-SMT-TR1 which is essentially the same chip that is 3mm instead of 6mm. Has anybody tried this chip?
NuclearPhoenix wrote 12/18/2022 at 21:45 point
Yeah, unfortunately they sold out just a week ago or so. I didn't test the MICROFC-30035-SMT-TR1, but it's more or less completely identical except for the smaller size. Would be interested too if anyone tried it out, pretty confident it would work.
gary.gonnella wrote 12/15/2022 at 17:46 point
Thanks for the answer, I will investigate the options.
gary.gonnella wrote 12/12/2022 at 18:59 point
I have found all the parts except the SiPM carrier board. It would rather expensive to have a 1 of made. Any thoughts, or am I just being thick headed?
NuclearPhoenix wrote 12/12/2022 at 19:11 point
You don't need it, that's why it's optional. If you want to, you can solder wires directly to the SiPM, but keep in mind that can be a bit tricky. The pins are pretty small after all, but it's definitely possible.
Otherwise, I can recommend you AISLER or JLCPCB, if you're looking for the cheapest PCBs out there.
