Hackaday.io Hackaday.io
Sign up Log in
Open source Solar system
A project to make a solar power system
corsixCorsix
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
2.5k views
6 comments
20 followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 5
    • View all
  • Logs 8
    • View all
  • Instructions 0
  • Discussion 6
  • Supplyframe DesignLab: 2022 Hackaday Prize
View Gallery
Public Chat
2.5k
6
20
15
Team (1)
  • corsixCorsix
Join this project's team
  • Great Scott lab
  • Odrive
shelved project
hardware
solar power manufacturing odrive 2022hackadayprize
Related lists
solar project list
list of ideas
This project is submitted for
  • Hackaday.com Tip Line
  • Reuse, Recycle, Revamp
This project was created on 05/03/2022 and last updated 3 years ago.
Description
Open source project for a solar farm with automation and testing of solar viability. Also some basic economics of the system and scaling. First goal of the project is to be able to sell the solar power to the power grid. Ultimate end goal is to combine solar power with agricultural production and do some sort of agrovoltaics or other passive income usage.
Files
FYX596DJIYU45LL.ino
servo arm accentuation for solar tracker - made by GreatScottLab
ino - 1.22 kB - 05/07/2022 at 13:31
Download
Components
  • 1 × Odrive pro https://eu.odriverobotics.com/shop/odrive-pro
  • 1 × SmartSolar MPPT 100/20 Bluetooth https://www.victronenergy.com/solar-charge-controllers/smartsolar-mppt-75-10-75-15-100-15-100-20
  • 2 × Solar panel 24V 300W https://www.solorder.se/solpaneler-husbil/solpanel-300w-24v-perc-svart
  • 2 × Fuse 24V AliExpress.com
  • 2 × Reversal diod 20A AliExpress.com
Project Logs
Collapse
  • Mppt and storage problems
    Corsix • 06/15/2022 at 18:01 • 0 comments
    So i have a larger problem where my Solar Mppt charger won't work with both solar panels if the battery voltage is to low, its only rated for 360w when using a 12v system. So thats why i haven't updated in a bit and have been putting the project on bit of a hold until i get some funds to acquire a 48 volt system for energy storage. I have been doing some other projects on the side such as assembling a mobile weather station instead.
  • Power Storage
    Corsix • 05/27/2022 at 19:40 • 0 comments
    Got my hands on a LFS105 12V 105Ah flooded batteri.
  • Stuff has arrived!
    Corsix • 05/24/2022 at 14:04 • 0 comments
    Now most parts have arrived. Still waiting on some things but now I have gotten my hands on the more important parts so I can start experimenting.
    I did now though noticed that I have forgotten to buy some important parts for hooking it all up together. More specifically the MC4 Connectors for the solar panel and corresponding cable for it hehe. But no worries, I will just order some. While I'm at it I might order some more interesting sensors for a weather station and some other equipment for IoT.
    The solar pannels are much bigger then one expects haha, I diden't have a banana for scale but i did have a tomato. But damn, isn't the panel beautiful, also got that sweet matt black finish on the sides!
  • Automation and brains
    Corsix • 05/10/2022 at 16:08 • 0 comments
    Also bought some things for automation and controlling things.
    https://www.amazon.se/dp/B07BVXT1ZK?psc=1&smid=A3BI8G9NTBZUKM&ref_=chk_typ_imgToDp
    https://www.amazon.se/dp/B086V8X2RM?smid=A1X7QLRQH87QA3&ref_=chk_typ_imgToDp&th=1
    https://www.amazon.se/dp/B083121193?smid=A6680RMGYRY9N&ref_=chk_typ_imgToDp&th=1
  • Battery hookup
    Corsix • 05/10/2022 at 14:58 • 0 comments
    Next thing to acquire is the components for the batteries, inspired by Martin Johnson - Off Grid Living. Now i'm just waiting on all my components to arrive. Will be working on some software in the meantime.
    Victron Energy BMV-712 Smart batterimonitor
    AWG 10 silikon cable 6m  black and red
    10 x cable attachments 6 mm²
    8 AWG-3/0 AWG cable tool
    https://www.amazon.se/gp/product/B084M2XYK4/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
    https://www.amazon.se/gp/product/B07569DLLT/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&th=1
    https://www.amazon.se/gp/product/B074J8HG4W/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
    https://www.amazon.se/gp/product/B09R1QQY9J/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
  • The initial idea
    Corsix • 05/09/2022 at 23:49 • 0 comments
    Here is a sketch of the system i was thinking initially with all the major components.
  • The real deal
    Corsix • 05/09/2022 at 23:38 • 0 comments
    So after some research i decided on 2* 300w 24v solar panels. I also bought a Mppt solar charger from Victron energy. There is a lot of other version and prices, but this was the best and cheapest that fit my specs that i wanted with my budget.
  • Starting out
    Corsix • 05/04/2022 at 20:27 • 0 comments
    So im getting the basics of solar tracking by using a Raspberry Pi and checking already open source projects available in the scope of the project. i was thinking of using a Odrive to control a motor. the idea is to following the sun in the most optimal angle, starting with one axes of movement.
View all 8 project logs
Log In/Sign up to comment
Sign up with Github
OR
teraz wrote 05/04/2022 at 13:26 • point
Please make a router with 365 day time working
Corsix wrote 05/04/2022 at 18:52 • point
Like local area wifi router?
teraz wrote 05/07/2022 at 12:23 • point
yes,
mesh Wifi for example B.A.T.M.A.N.
Corsix wrote 05/10/2022 at 18:43 • point
Yes that's a good idea, will try to implement this feature of B.a.t.m.a.n
Jim wrote 05/03/2022 at 20:24 • point
"A instructunal" ?   Do you mean 'An instructional'  ?
Corsix wrote 05/04/2022 at 00:40 • point
I uppdated the description and scope
Hackaday Prize 2020
Solar-powered charging station for 9 cell-phones at once. Learn here how to build the solar panel and the charging station
Project Owner Contributor
I'm Talking on Sunshine
amiravniamiravni
This is the very first prototype iteration for an ultra low power home DC electrical system using solar photovoltaics
Ultra low power home DC electrical system - 1st
miguel-tomasMiguel Tomas
Indoor solar power system using Victron MPPT, AGM battery, and inverter for small household appliances.
Solar Panel Project
jin-wen-thai-lowJin Wen Thai Low
This project is migrating to another platform. Thanks to everyone who stopped to check it out!
Springhouse
jeremiahJeremiah
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Open source Solar system", please tell us the reason.
Send message
Remove Member
