Trash Printer -Version 3 -10-22-2022.zip
This is a zip folder of the complete documentation, it's the same files, but easier to download (and share)
x-zip-compressed -
38.18 MB -
10/23/2022 at 04:17
Download
Marlin 2 for Trash Printer V3 9-28-22.zip
x-zip-compressed -
5.86 MB -
10/10/2022 at 05:43
Download
Trash Printer V3 - 10-6-2022.skp
SSEYO Koan Play File -
26.54 MB -
10/10/2022 at 05:42
Download
B5 - Extruder Bottom Spacer (1x).stl
Standard Tesselated Geometry -
70.79 kB -
10/10/2022 at 05:42
Download
B6 - Extruder Bottom Spacer (3x).stl
57.50 kB -
10/10/2022 at 05:42
Download
B4 - Extruder Bottom Spacer (1x).stl
59.07 kB -
10/10/2022 at 05:42
Download
X3- X-carriage top plate (x1).stl
54.77 kB -
10/10/2022 at 05:42
Download
B3 - Extruder Bottom Spacer (1x).stl
75.47 kB -
10/10/2022 at 05:42
Download
B2 - Extruder Bottom Spacer (1x).stl
75.47 kB -
10/10/2022 at 05:42
Download
X1 - X-motor plate (x4).stl
91.39 kB -
10/10/2022 at 05:42
Download
Z1 - Z-motor plate (x4).stl
42.27 kB -
10/10/2022 at 05:42
Download
B1 - Extruder Bottom Spacer (1x).stl
55.55 kB -
10/10/2022 at 05:42
Download
Y1 - Y-motor plate (x8).stl
50.86 kB -
10/10/2022 at 05:42
Download
X2- X-carriage bottom plate (x1).stl
125.47 kB -
10/10/2022 at 05:42
Download
T1 - Extruder Top Spacer (1x).stl
93.05 kB -
10/10/2022 at 05:42
Download
R1 - X-carriage rollers (x8).stl
50.28 kB -
10/10/2022 at 05:42
Download
T2 - Extruder Top Spacer (4x).stl
41.68 kB -
10/10/2022 at 05:42
Download
C1 - Controller Mounting Plate Rambo.stl
29.96 kB -
10/10/2022 at 05:42
Download
E1 - Extruder Shaft Coupler (x2).stl
20.79 kB -
10/10/2022 at 05:42
Download
R2 - Y-carriage rollers (x8).stl
50.28 kB -
10/10/2022 at 05:42
Download
X2- X-carriage bottom plate (x1).svg
svg+xml -
7.69 kB -
10/10/2022 at 05:41
Preview
T2 - Extruder Top Spacer (4x).svg
svg+xml -
1.67 kB -
10/10/2022 at 05:41
Preview
X3- X-carriage top plate (x1).svg
svg+xml -
4.79 kB -
10/10/2022 at 05:41
Preview
T1 - Extruder Top Spacer (1x).svg
svg+xml -
6.51 kB -
10/10/2022 at 05:41
Preview
E1 - Extruder Shaft Coupler (x2).svg
svg+xml -
1.80 kB -
10/10/2022 at 05:41
Preview
X1 - X-motor plate (x4).svg
svg+xml -
6.96 kB -
10/10/2022 at 05:41
Preview
C1 - Controller Mounting Plate - RamboV1.4 (x1).svg
svg+xml -
3.18 kB -
10/10/2022 at 05:41
Preview
Y1 - Y-motor plate (x8).svg
svg+xml -
5.46 kB -
10/10/2022 at 05:41
Preview
R2 - Y-carriage rollers (x8).svg
svg+xml -
6.58 kB -
10/10/2022 at 05:41
Preview
R1 - X-carriage rollers (x8).svg
svg+xml -
6.58 kB -
10/10/2022 at 05:41
Preview
B5 - Extruder Bottom Spacer (1x).svg
svg+xml -
2.44 kB -
10/10/2022 at 05:41
Preview
B6 - Extruder Bottom Spacer (3x).svg
svg+xml -
2.01 kB -
10/10/2022 at 05:41
Preview
B1 - Extruder Bottom Spacer (1x).svg
svg+xml -
2.11 kB -
10/10/2022 at 05:41
Preview
B3 - Extruder Bottom Spacer (1x).svg
svg+xml -
2.87 kB -
10/10/2022 at 05:41
Preview
B2 - Extruder Bottom Spacer (1x).svg
svg+xml -
2.87 kB -
10/10/2022 at 05:41
Preview
Z1 - Z-motor plate (x4).svg
svg+xml -
4.18 kB -
10/10/2022 at 05:41
Preview
B4 - Extruder Bottom Spacer (1x).svg
svg+xml -
3.07 kB -
10/10/2022 at 05:41
Preview
Open Source Fist.svg
svg+xml -
6.23 kB -
10/10/2022 at 05:41
Preview
