The boat hull is complete build of wood with a fiberglass paste to reinforce and smooth the bottom surface of the hull, this feature has required a lot of attention in terms of painting and water protection paint, there are 3 layer of pore stopper, 3 layer of paint and a final layer of opaque finish.
In the central box of the boat take place the motor, all the electronic devices and the electric water pump for the cooling.
The motor was designed with Fusion 360 and then realized with 3D printed ABS, the motor used is a brushless out-runner connected to a gearbox created using gears from an old paper printer.
This gearbox also incorporate a centrifuge pump that can be used for the cooling of further devices, in the "file" section you can find some picture about the motor and the central motor case.
Davide Cagnoni
Mike Rigsby
Soo-Hyun Yoo
ken.do
