I found out how to use double numbers in the Psion L1VM. The bytecode of the L1VM (.l1obj) uses the modern IEEE 64 bit double numbers. The ARM CPU in the Psion 5MX uses a different format for double numbers. So how can this be fixed? In my "math circle" program I defined Pi as a string. Then the string is converted to a double number. This just works fine. You need to do this with any double number you want to use.
You can find more information on my blog: https://midnight-coding.de/blog/psion/2024/02/10/psion-linux-kludged.html There is also a download link for the Kludged Linux: Debian Sarge. This includes the older full archive with the include files and the gcc compiler. So you can build your own C and C++ programs there!
jay-t
Olav Schettler
Ember Leona
CanHobby.ca
Elbert
Is there a pre-made image for the whole distro? As it can boot directly from CF card I was thinking it would be great to have everything on one single img file, as most of the pieces are spread all over and the software for the old linux build for example is even harder to find (the links in some tutorials to specific software for this linux version do not work anymore).
Awesome how such limited machine can run Linux so well; and yet modern machines have problems. Also the physical keyboard is really nice.
