Hackaday.io Hackaday.io
Sign up Log in
PD-controlled Inverted Pendulum Robot
This robot uses proportional and derivative control to balance itself on 2 wheels for up to 5 seconds.
nyeli-kratzNyeli Kratz
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
0 followers
  • Description
  • Details
  • Files 5
    • View all
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
196
0
0
1
Team (1)
  • nyeli-kratzNyeli Kratz
Join this project's team
completed project
hardware
pid control Inverted Pendulum
This project was created on 07/17/2022 and last updated 3 years ago.
Description
The objective of this project was to create a robot which only makes contact with the ground on two coaxially mounted wheels and is able to balance itself on level ground using PD control based on feedback from an IMU magnetometer. We made an effort to put the heavier components as high on the robot as possible to move the center of mass farther away from the axis of rotation, giving the robot the maximum possible amount of time to catch itself before it falls while remaining within the size constraints of the project.
Details
Files
IMG-5068.mov
Video of the robot balancing itself.
quicktime - 8.59 MB - 07/17/2022 at 14:02
Download
IMG-5066.mov
quicktime - 7.37 MB - 07/17/2022 at 14:02
Download
IMG-5056.mov
quicktime - 9.25 MB - 07/17/2022 at 14:02
Download
Mechatronics Inverted Pendulum writeup.pdf
Final project writeup including strategy and design process.
Adobe Portable Document Format - 4.12 MB - 07/17/2022 at 14:02
Preview
FINAL_INVERTED_PENDULUM.ino
Arduino code used to control the robot.
ino - 5.46 kB - 07/17/2022 at 14:02
Download
Log In/Sign up to comment
Sign up with Github
OR
The 2018 Hackaday Prize
This project is aimed at creating a robot based running ROS which allows us to turn any generic robot hardware platform into a smart robot.
Project Owner Contributor
ROS Starter Robot
adityaAditya
School Project. This robot attempts to have 2 servo arms and 4 wheels, all of this controlled via wireless with electromyography sensors.
Electromyography controlled robot
valentin-ortegaValentin Ortega
Hackaday Prize 2019
Mimicking human movements precisely using a control gloves on a robot hand side.
Virtual Pressence Robot
nikhil-m-jebyNikhil M Jeby
The manipulator
SCARA robot
karolgalkaKarolGalka
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "PD-controlled Inverted Pendulum Robot", please tell us the reason.
Send message
Remove Member
