Found a good starting point to talk with the MSP430, but sadly it runs into a weird bootloader password issue.
goodfet.bsl -P ./goodfet.hex --fromweb
Use -h for help
Use --fromweb to upgrade a GoodFET.
MSP430 Bootstrap Loader Version: 1.39-goodfet-8
Invoking BSL...
Transmit password ...
Use -h for help
Invoking BSL...
Traceback (most recent call last):
File "/usr/local/bin/goodfet.bsl", line 1987, in
main(0);
File "/usr/local/bin/goodfet.bsl", line 1887, in main
bsl.actionStartBSL()
File "/usr/local/bin/goodfet.bsl", line 1166, in actionStartBSL
self.txPasswd(self.passwd) #transmit password
File "/usr/local/bin/goodfet.bsl", line 1136, in txPasswd
wait=wait) #if wait is 1, try to sync forever
File "/usr/local/bin/goodfet.bsl", line 801, in bslTxRx
rxFrame = self.comTxRx(cmd, dataOut, len(dataOut)) #Send frame
File "/usr/local/bin/goodfet.bsl", line 480, in comTxRx
rxHeader, rxNum = self.comRxHeader() #receive header
File "/usr/local/bin/goodfet.bsl", line 386, in comRxHeader
if not hdr: raise BSLException("Timeout")
__main__.BSLException: Timeout
aha! So the tutorial uses a capital P where the flag should be a small p. Or not, maybe the password stuff is set somewhere else or while compiling. writing the ./prebuilt firmware worked.
board=goodfet42 goodfet.bsl -p goodfet.hex
Well that wasn't really a solution, but somehow I got it to except the firmware, probably by using the "fromweb" flag for it, where it wasn't confused by all that.
Sure, I could try and do the same hard work that plenty people have done before me, do miserably and fail - or I could just try and get stuff from back then working. So within chip shortage I tried to get hold of the MSP chip that's featured on the GoodFET, a DIY JTAG and more probe, that isn't obtainable anywhere. Thankfully everything I needed was accessible and so I started redesigning the GoodFET in KiCad, swapped some parts and added rounded corners basically and ordered the boards at OSHpark. Why did I do that? Because all the tutorials from 2010 basically start with "connect your GoodFET to the im-me messenger" and well I need one then, of course.
If you get yours working, I'll bring mine to Congress and we can chat. Or scan the lower bands. Or...
