1AEHCI Basic Build Instructions
- Print Chassis, Keyboard Lock Block, Trackpad Lock Block
- Install Heat-set inserts into Lock Blocks
- Install Penglin USB-C Panel Mount connector in the Keyboard Lock Block
- Mount 'Mokin' USB Hub in the AEHCI Chassis, using a 90 degree USB-C connector to attach the hub's USB-C Input to the Penglin Panel Mount
- Connect @pple lightning cables to the USB 2.0 ports on the Mokin Hub, and zig-zag them through the integrated cable management channels in the AEHCI Chassis
- Trace one lightning cable through the narrow cable opening in the back of the AEHCI chassis, so it can double over and connect to the back of the keyboard during step 10
- Position the Trackpad Lock Block on the Right Front side of the Magic Trackpad, and slide both parts into place on the AEHCI Chassis
- Use a short ~4mm M3 screw to secure the Trackpad Lockblock in place
- Connect the Magic Trackpad Lightning Cable
- Position the Keyboard Lock Block to the side of the @pple Magic Keyboard, and slide them both into position, pivoting on the right side, and moving down.
- The Penglin Panel Mount Connector must socket into the 90 degree USB-C connector. It may be necessary to adjust the position of the connector with a prodding tool
- Use a short ~4mm M3 screw to secure the Keyboard Lock Block in place
- Connect the lightning cable to the keyboard
Basic Assembly is complete. I will write a more detailed set of build instructions if requested.
