Updating Designs
2 days ago • 0 commentsHowdy! It's been about 3 years since I started this project, and I've learned a few things since then.
1. I should have standardized the size of modules to be multiples of 10.2. I should have spaced the holes at multiples of 20 or 10
3. Cable coming out of the top is functionally inferior to cable sticking out the back
4. I should have designed it for "normal sized" print beds.
5. More port clearance everywhere. I did all this work to integrate a docking station, it kills me when I can't get to a port I need.
6. Track pad's charging port is not accessible without removing the keyboard. This is a big one.
7. There is interest in a right-handed variant. I think a literal X-axis swap is possible.
So I'm gonna do those things! -
Trackpad RHS Module
12/29/2023 at 03:42 • 0 commentsI almost referred to this as a Sidecar. Can that term work? It's definitely sexier than "module"
I've decided on a whim to mount a second trackpad to this thing.
So here's the idea.. trackpad slides into this unit, and the screw tension holding this on is enough to hold the trackpad in place. No, not quite...
OMG, I just got a GREAT idea...
The Trackpad slots in, the module is attached to the main chassis...
and then this orange decorative piece is screwed in, and it's actually a lock block, putting tension on the aluminum base of the trackpad!
Pretty clever, right?Final touch is to add the mounting holes to the back...
Looks pretty good!
... and since I can't leave well enough alone, let's add some decorative flair that is also a support structure...
That should do! I bet it can print fully without supports. Though the design isn't my favorite.
Modular Cyberdeck Creation Kit : Design Principles
08/17/2023 at 17:36 • 0 commentsThis "log entry" describes the deliberate design choices I will (try) to adhere to while I expand on this project.
Practical Engineering Choices
- Consistent Spacing from the Center of Mounting Points
- Vertical distance between mounting holes is 25mm
- Horizontal distance between mounting holes is 25mm or 50m
- Horizontal distance between mounting holes and the 'side' of a module SHOULD be divisible by 5
- The goal is to facilitate accessories and modules to connect across multiple modules
- Minimize Support Material
- Parts will be designed to minimize the need for support material
- M3 Hex Machine Screws as standard connectors
- Various lengths and head styles may be used
- Visible Screw heads are part of the aesthetic design
- M3 Heat-Set Inserts as standard
- 4mm depth as standard
Artistic Style Choices- Screw Heads will be visible, and are considered part of the artistic design
- Hexagonal Access Ports and "Speed Holes"
- Where necessary to include holes and slots, a hexagon should be used
- A flat surface of the hexagon should be parallel to the bottom of the component
- The sides of a hexagon can be arbitrarily stretched to meet the practical engineering need of a hole or slot
Practical Concessions
These are some practical choices I've made that may be sub-optimal, but should be acknowledged as tested and considered.
- Flat sides for Modular Interfaces
- The sides of a part that are compatible with other modular components should be parallel or perpendicular to the normal.
AEHCI Cyberdeck Writeup
07/26/2023 at 22:23 • 0 commentsThe Apple Ecosystem Human Computer Interface (AEHCI) is a small-form-factor input/output cluster designed to give you all the connections and interfaces you need, wherever you are.
Built around a universal USB-C Hub, the AEHCI can connect to most devices that support USB-C, and provides the following:- 60% Keyboard
- Multi-Touch Trackpad
- 65w, 20K mAh power supply
- 3x USB 3.0 ports
- 2x HDMI
- 1x DisplayPort
- Gigabit Ethernet
- SD and Micro-SD Card Reader
The trackpad is positioned underneath the keyboard, with ample exposed area for left hand, 2-finger vertical scrolling and left hand thumb pointer control. This novel positioning works well to reduce the footprint of the device while improving ease of access for common activity.
The device features a convenient carry handle that also works as a mobile device stand, facilitating convenient use with tablets and smartphones.
The AEHCI includes a removable clamshell mount for the Steam Deck, transforming it into a gorgeous all-in-one mobile workstation and gaming machine.
AEHCI Gallery
The AEHCI without attached devices.
A view of the bottom of the AEHCI, you can see how I built cable guides into the chassis to give all the wires somewhere nice to go.
The Keyboard and Trackbad are both Bluetooth compatible, and feature their own batteries, but I built all of this with reliable, consistent wired connectivity in mind.
Connected to the Steam Deck, the keyboard and trackpad work well to unlock the full potential of the hand-held workstation.
The AEHCI uses two pair of Lenovo laptop hinges to support the deck at an array of convenient viewing angles, and to clamshell closed for safe travel.
The AEHCI hinge doesn't block access to any ports, and includes ample tools for cable management, and plenty of room for additional accessories.
Not yet photographed, the Battery Module includes an optional storage box as an alternate configuration.
Multiple storage modules can be connected together if you need a bunch of connected interior storage space, though I haven't had a need for that yet.
I hope you've enjoyed seeing the AEHCI! All the files necessary to create your own, along with a shopping list, are attached to the project. -
AEHCI Prototype Complete?
07/26/2023 at 16:30 • 0 commentsI am at a weird place. I have been iterating on this model for 6 months, I am at version #110 of my Fusion 360 file, and I think I'm... done?
Is there anything that needs to be improved?The Chassis
- Prints in 2 pieces -Reinforcement Bar is important.
- I think I can adjust the model to print in just one, but I kind of like the color splash of the reinforcement bar.
- Reinforcement Bar prevents larger UISB 3.0 devices from attaching to the 'front'. Extensions can be used.
- Cable Management could benefit from a couple more guided channels
- I can't believe how effective the current system is though!
- (Optional) Right Side Handle is hard to source
- I found a metal handle in the garbage, and I used that. I don't know if I can find an equivalent part online.
- Chassis has built-in cutouts on the inside for rubber feet to help cushion the keyboard and trackpad, but the feet I bought for the bottom are too thick.
The Hinge
- Imperfect, but it's absolutely functional. Could it work with just 2 hinges instead of 4?
- Earlier testing had too much wobble with a single connection point, even if it was solid and attached via 2 screw mounts.
- Design-wise, it doesn't blend with the aesthetic elements of the rear of the deck very well.
- Asymmetry and parts mismatch is part of the Cyberpunk aesthetic... but it still bothers me.d
The Handle
- Uses a picatinny rail, but has no picatinny accessories.
- Current Design has cutouts requiring the handle to mount in a single spot, AND it requires attachment to the Modular Storage Box, which has non-standard hole spacing
- Without the Modular Storage Box, the Right Side Handle is adequate.
- Current Design has it attached with thumb-screws, which allows for relatively easy removal.
- Attaching the hinge is a little finnicky, and the screws need to be tightened down hard.
- I could improve on the attachment tech.
The Modular Storage Box
- BaseUS 20kmAh battery is secure enough, but has some wiggle
- This is a direct consequence of form-over-function aesthetic, as the heavy battery is held in place with a small contact patch at the end, rather than in the middle.
- I have ample mounting points for an optional support strap or something, but it doesn't seem strictly necessary.
The Steam Deck JSAUX Modcase Mount
- The mount points on it are positioned haphazardly, not universally compatible
- I could cover the entire backside in holes, so users can install Heat-Set inserts anywhere they want, but why bother? The only accessories I am attaching at this point are custom-designed cable management, and I doubt anyone will actually make their own AHCI.
- The Steam Deck is a little "floppy" when the 'clamshell' is closed.
- Old laptops used little clips to help secure the lids closed, but I don't see the return in all that effort
- I built a fixed hook to secure the deck, but it gets in the way during use.
- I'm thinking an elastic garter could easily do the trick, but where would I put it when it's not in use?
I think that's my whole list. Are any of those items worth the effort to fix?
Storage Boxes
06/23/2023 at 19:59 • 0 commentsIt's hard to know when a piece of art/engineering is done. I guess when there's nothing left to take away?
Oh well! Time to add more Stuff!
I've been iterating on what I am calling the Multipurpose Storage Module.Initially designed to house a BASEUS 20,000mah power brick, I also wanted to make a storage box that would fit in place if someone didn't have this power brick, OR if someone just needed space to store wires.
Here's the "Basic" Storage Box.
It gets secured by a friction screw on the rear-left, and either a thumb-screw on the front right, or some sort of elastic/form wire strap that slots into that cut-out on the left side.
Then I realized that this storage box could be used for EVERYTHING. At least as an intermediate step while I work on more custom modules!
Want to add an SSD to your cyberdeck? Toss it into a storage box!
Need more USB ports? Put a hub in there!
You could stack them, and get a lot of extra room in your cyberdeck... as long as there is room to connect adjacent boxes.
This one goes in the middle.
This is a great example of Scope Creep, but check it out!Now even the basic AEHCI has support modules to add anything you want!
Perfect is the Enemy of Good
06/17/2023 at 22:04 • 0 commentsI've done so much work on this, I think it's ready to share with others. Even though It's not perfect or really complete.
So without further ado, BEHOLD! The Apple Ecosystem Human Interface Cluster!
The AEHIC looks sharp on a desktop, and is fully capable of connecting via USB-C to your workstation.
Although both the Trackpad and the keyboard support Bluetooth, I leverage wired connections to ensure reliability and connectivity as it is moved between multiple computing devices.
Right Side allows access to Display Port and gigabit Ethernet. Additional devices could be connected via mounting points.
Left Side has mounting points for additional modules, and (at the moment) has a USB-C cable hanging off. It was recently connected to a battery module that I have abandoned.
Rear of the AEHIC shows additional ports and the handle, which is both a handle and a tablet/mobile stand.
My cyberdock works as a lapdock, compatible with DEX Devices (though the hub must be powered)
Like most things in my life, I built it to play video games. The cyberdock mounts cleanly to the Steam Deck, shown here wearing a white skin, and a JSAUX Modcase.
The current mounting solution for the Steam Deck is a fixed, albeit removable bracket.
Just imagine how slick this will look once I get a folding. clamshell mechanism integrated!
Grabby Little Hands
06/14/2023 at 21:56 • 0 commentsThe Cyberdock is designed around the Steam Deck, but I want to make sure it's compatible with other common computing devices as well, so I've added some adjustable grips large enough for an ipad pro. An additional benefit is that this can be used to support a tablet device with a very nice screen, and use Steam Link to wirelessly (boo) connect to the deck. Under the right circumstances, it could give you a nicer lookling, larger screen for your gaming pleasure.
I am making significant use of heat-set inserts, and thumb screws.
Updated Printables..
06/14/2023 at 18:14 • 0 commentsI updated my Printables files for the [JSAUX Modcase Design Environment] and reached out to JSAUX to invite them to include my files in their official development kit!
The current build of the Apple Ecosystem Human Interface Cluster (Cyberdock) is looking good!A few small adjustments are needed for the 'Fixed Steam Deck Device Mount' component
The right Fit...
06/11/2023 at 22:05 • 0 commentsTHE WORK continues, albeit crudely at the moment.
My goal is to make a secure mount for the steam deck that can be attached to the handle of my cyberdock.
A week or so back, I made a mockup of the JSAUX mounting hardware, and discovered that they had made their own tools. Good news, it turns out the tools they released are inadequate for my purposes. TLDR, they just made sample printables that connect to the central mount point, but not to the right side stand connectors... so my creation is a solid value add!
I'm running through a series of test prints to get a piece that fits *perfectly* to all of the rear-mount points.
As you can see, at the moment, there is some misalignment between 'central' mounting point, and the 'stand' mounting points.
I'm not sure where I went awry... how I made such a large error, but I'm guessing the model I used for the 'central' mounting point got vertically flipped. Or I measured bad.
Either way, not hard to fix, but then I need to update the JSAUX Mounting Kit Fusion Project and the models on Printables. Trying to make my stuff useful to others adds significant overhead.
Oh RIGHT. The Handle. Using a thing is an awesome way to realize how much it sucks.
And my handle SUCKS.
Here you can see some of my recent development work on the handle.
The first one was actually good. It felt solid and had good balance.
Future iterations where I attempted to integrate a device stand made the balance off, and holding it was uncomfortable... though I still haven't given up on the idea of making the handle a device stand.
The current design shown above, but not yet tested, is a 3 part handle (Left, Right and Rail). The 'Rail' is the actual handle, and it's connected to the cyberdock with thumb screws that allow the user to adjust the spacing to allow for a range of device thicknesses. The practicality of this is yet untested.Additionally, this rail will be used to mount the Steam Deck Mounting hardware, since the deck is relatively large and heavy, I am using the Left/Right handle mounts and the rear of the chassis itself to help support the deck.
I chose a standard 'picatiny rail' to augment the handle, giving you something interesting to touch and more importantly providing multiple points of contact that can prevent the Steam Deck mount from slipping around, since it's going to be held on by thumb screws.
