Documentation: https://stanleyprojects.com/projects/laserprojector_v2/
Source code + Design files: https://github.com/stanleyondrus/LaserProjectorV2
Battery-powered, ESP32-based laser XY scanner with auto-homing and wireless control
LaserProjector_REV_04_GBR.zipGerberx-zip-compressed - 164.23 kB - 10/30/2022 at 17:48 |
LaserProjector_REV_04_schematic.pdfSchematicAdobe Portable Document Format - 63.16 kB - 10/30/2022 at 15:46 |
HomingSensor_REV_01_GBR.zipGerberx-zip-compressed - 12.80 kB - 10/30/2022 at 17:48 |
HomingSensor_REV_01_schematic.pdfSchematicAdobe Portable Document Format - 14.83 kB - 10/30/2022 at 17:48 |
cad_models.zip3D CAD Modelsx-zip-compressed - 466.21 kB - 10/30/2022 at 15:45 |
I've been thinking about drivers with stall detection support, but I'm afraid that feature doesn't work with geared steppers (the plastic pin will most likely break before the stall current increases above the threshold).
The TMC "Silent Stepper" drivers have collision detection. The pin you are using for optical detection could just hit an object. No extra wiring or devices needed. They stop without doing any damage as current starts to climb - I think.
