Make it scalable.
08/31/2023 at 07:53 • 0 commentsBy adding multi-taps for expansion to the device for the controller, the logic equation can be expanded more and more.
Structure of the system
08/31/2023 at 07:50 • 0 commentsWe use GameControllerizer, which makes it easy to create your own controllers.
Japanese NES controllers can be controlled via D-SUB 15-pin.
![コネクタ]()
Pins to be used include
![pin]()
Connect the two 15-pin D-SUB connectors and the M5Stack
GameControllerizer via Grove (UART control)
When everything is set up, it will look like this.![]()
Manufacture of enclosures
08/31/2023 at 07:43 • 0 commentsThe housing is created with a 3D printer.
HIGEDARUMA
