Hackaday.io Hackaday.io
Sign up Log in
PICOmputer&Armachat TOUCH
Raspbery Pi PICO and CircuitPython
bobriciusbobricius
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2.4k views
3 comments
25 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 3
View Gallery
2.4k
3
25
23
Team (2)
  • bobriciusbobricius
  • david-guidosDavid Guidos
Join this project's team
ongoing project
This project is submitted for
  • Cyberdeck 2023
This project was created on 12/21/2022 and last updated 3 years ago.
Starting from
Buy on Tindie
has orders / reviews
Ships from
Description
Features:
-Based on Raspbery Pi PICO
-1.69" IPS LCD 280x240
-30 touch buttons QWERTY keyboard with optional backlight
-135mm x88mm x 1.6mm dimensions
Supported displays:
-12pin st7789 IPS 280x240 via flex cable 1.69" inch
-any display with popular china module pinout GND,VCC,SCK,DAT,RES,DC,CS,BACKLIT connected externally with wires
Details
Log In/Sign up to comment
Sign up with Github
OR
SalvageYourself wrote 07/18/2023 at 05:00 • point
nice design! how much is the distance they can contact? It is not so long as datasheet said in my case.
aaaaaa wrote 07/05/2023 at 16:55 • point
too small scren in emergency situation,
to big device , look this https://youtu.be/1K3lT_ayaP8?t=1385
aldolo wrote 12/22/2022 at 06:15 • point
touch keyboard is ideal for a zx80 clone
A 7-inch external touch screen for your windows laptop/pc, this screen can be also used with the Raspberry Pi.
Project Owner Contributor
External HDMI Touchscreen for Windows & Raspberry
akarshagarwal98akarshagarwal98
using JAVA and Pi4J
Display messages on 16X2 LCD | Raspberry Pi
bikash-narayan-pandaBikash Narayan Panda
A hardware-based tutorial on how to set up a 5-inch Capacitive Touch Screen Display with the Raspberry Pi, making it compact and portable.
5-inch Capacitive Touch Screen Display Setup
electorialsElectorials
raspberry pi controlled ws2812 strip behind boxes, tiny webserver and script to show what's where
box guide
davedarkodavedarko
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "PICOmputer&Armachat TOUCH", please tell us the reason.
Send message
Remove Member
