The mini µmixctrlr plan
the mini µmixctrlr is taking shape. by lack of a project box at hand.. roll your own box. keep it simple was a given to use discarded tech is a must in this age of resource shortages. to the chagrin of the maker community and even large companies that have been experiencing this low supply of resources for years. thus, i got to it. a quick working proto type is almost finished, just the 5 potholes need to be drilled and the two mouse button knobs extended to the top of the board by extending the buttons with some piece of plastic tube to switch them. a nice overlay with markings in a dxf file to cover the top. the faders and extra control pots are multiplexed spi or i2c and connect to the mouse usb sensor and hid device next week. the mini is all part of the touch screen bigger one i designed in freecad. double fader blocks easily integrated by adding an extra connection board in between them. thus making the two fader blocks extendable to how many you could need for your own midi ctrl mixerboard. this version fits nicely on any ones home studio desk. the design of the sides is such that a one cm block extends inward with a some sort of plastic ribbon strong enough to withstand a day in the gig bag and keep moisture out. the blocks inside hold the pcb down in place and support the entire construction. thus saving on materials like fasteners etc. rollin on a budget should spark invention and smarter design. this project is meant to be easily build by other #diymusicians and #opensourcehardware is at the core of my ideas and plans going forward. all will be put in github hackaday.io with docs and code. demo of the daw controller will go onto the aliendnatronics youtube channel. but for now.... a happy holiday weekend all.
Description : Serial usb mouse pcb inbetween 2 faders with three buttons and scroll for midi ctrl assigning. For use with any DAW
BOM:
2 faders
2 fader knobs
1 usb serial Mouse
2 proto boards to fasten and run xtra wires to and from
1 avr attiny85
2 top and bottom plates 86 mm x 139 mm of any sturdy material pvc wood metal
4 fasteners
8 nuts and washers
form: fader to fader clearance +470mm depending on the stripped mouse pcb.
functions : scroll wheel+ButM ButL ButR
pro’s : easy to
find a discarded USB mouse at home adds a private address to be connected through i2c
cons :
This two fader mini version controller is a pre to the full daw controller designed in freecad and described in this project
a touch screen is part of the bigger project for this project screen "add-on"
The MIO GPS convertion plan
Converting an old car GPS system as a touch screen controller seemed like a great idea. The growing shortage of source materials and the growing chip shortages. Up-scaling old hardware to usable new ones.
Together with an extra stm32 Bluepill or attiny and i2c or spi for faster io functions to the knobs and faders. my home studio needed a Midi controller board. True, many store bought options are available, at not too steep prices. Although making one yourself is not an impossible task.
An old year 2000
model Mio 200 ns206 touchscreen GPS adapted to Android Pie OS serves
the job at hand. Donated by a friend the GPS system falls just nicely
into the 33x25 cm mixing console top setup. android studio ide can be downloaded for this purpose.
Yakumo Mio DigiWalker Sync in # lsusb
mio_getRegionData(): KernelIoControl(IOCT L_MIO_SYS_GET_REGION_DATA) returned 456 mio_getRegionData(): Region: HW Type = Cobia_300_32 mio_getRegionData(): Region: Display = Mio mio_getRegionData(): Region: Project code = N206 mio_getRegionData(): Region: SKU ID = 9601 mio_getRegionData(): Region: Map version = mio_getRegionData(): Region: Map region = mio_getRegionData(): Region: LCID = 0x809 mio_getRegionData(): Region: Version = 0x2 sys_getHardwareVersion(): KernelIoControl(IOCTL_HAL_READ_HW_VERSION) returned 100 updating from...Read more »
