Before we dive into the specifics of the Smart Recliner add-on, I would like to first address the construction and appearance of the device. Having lived with Multiple Sclerosis for over 35 years, I recognize that my fine motor skills are not as they once were, which has posed certain challenges, particularly given that I am working with one hand. As a result, there may be some imperfections in the device's construction, and for that, I sincerely apologize. I hope that you can look beyond these aesthetic details and instead focus on the true value of the Smart Recliner add-on—the functionality and convenience it offers. Ultimately, it is the positive impact this innovation can have that I believe is most important.
Who knows, maybe a couple unicorn stickers on it might make it pretty??
6/15 UPDATE: The project is now in the 'prototype' stage. The first, 'sloppy' concept stage mentioned above, has given way to a much more 'professional' look.
At least I hope so.
The Smart Recliner add-on is specifically engineered to improve the lives of individuals with limited mobility, such as myself, who face challenges when operating powered recliners using traditional controls. By incorporating innovative automation, this device makes reclining effortless and accessible for all users.
With a background as an FM radio broadcast engineer for nearly 15 years, followed by over 20 years of experience as a professional software engineer specializing in C#, I bring a unique combination of technical expertise and hands-on experience to the development of this solution.
The device:
Introducing the Smart Recliner add-on - Elevating Comfort and Convenience to New Heights!
Overview:
The Smart Recliner add-on is a device designed to enhance the experience of using powered recliners, particularly for individuals with limited mobility. The exciting part? t's not something you can just run out and purchase anywhere, since it doesn't exist! It introduces a level of automation to the chair, bed, or other purposes, revolutionizing the way you interact with your recliner. This device is independent, yet seamlessly integrates with your existing recliner controller, making the transition smooth and user-friendly.
Key Features:
- Dual Controllers: By default and the way powered chair controllers are wired, you can't simply buy a "Y" midi cable adapter and expect it to work. It will not. The Smart Recliner bypasses this limitation by allowing two controllers: the Main Controller and the Logic Controller. The Main Controller is your existing recliner's controller (2 or 4 button) and remains fully operational and transparent under the Smart Recliner's control. The Logic Controller, which also can be a 2 or 4-button model, serves as the automation hub, enabling a whole new level of convenience.
- Two modes of operation: The device offers two operation modes: timing-only and a more reliable and predictable mode that utilizes one or more optional "limit" switches. This advanced mode provides the advantage of precise control when a button is pressed.
- "Timing" mode home position recognition: When using the timing mode, the Smart Recliner "knows" the chair's position (assuming it was powered-up in the normal, upright position) by counting the duration the motor is engaged. "Up" button reduces th1e time, while "Down" button adds to it.
- "Switch" mode home position recognition: The optional limit switches positively identify the normal, upright position, regardless of what position the chair is, or when it was powered up. The two available limit switches are referred to as "Recline Home" and "Lift Home." While they seem to serve a similar function by 'closing' when the device is in its normal, upright position, their primary significance lies in providing the device with a clear indication of how it reached that position. Therefore, it is strongly recommended to employ the use of limit...
Stephen Craver
Julien OUDIN
Sebastian Baca
UPDATE: I unintentionally lied. I have business that will keep me from posting videos for a couple of weeks. Apologies!!
