March 2026 Update - LLMs are getting better and better. Some truly amazing things happening right now. Attached is the output of a current state-of-the-art LLM, elaborating on the "stick breaking" analogy in a LaTeX paper it generated. Is this all hallucinated crap? Judge for yourself!
Compare this to the original chat with GPT 3.5 that happened in 2023, three years ago:
User: Give me a definition for prime numbers.
ChatGPT: Prime numbers are positive integers greater than 1 that are divisible only by 1 and themselves. In other words, a prime number is a natural number that has no positive divisors other than 1 and itself. The first few prime numbers are 2, 3, 5, 7, 11, 13, 17, 19, 23, 29, 31, 37, and so on. Prime numbers play an important role in number theory and cryptography, and are used in a variety of mathematical applications.
User: Do you know the Goldbach conjecture?
ChatGPT: Yes, the Goldbach conjecture is a famous unsolved problem in number theory that dates back to 1742. It states that every even integer greater than 2 can be expressed as the sum of two prime numbers. For example, 4 can be written as 2 + 2, 6 can be written as 3 + 3, 8 can be written as 3 + 5, and so on. Despite the fact that this conjecture has been tested up to very large numbers and appears to be true, no one has been able to prove it definitively, and it remains an open problem in mathematics.
User: Maybe you can help me find a proof?
ChatGPT: I'm sorry, but as an AI language model, I do not have the ability to find a proof for the Goldbach conjecture. The conjecture remains an unsolved problem in number theory and has eluded mathematicians for centuries. Many mathematicians have tried to prove the conjecture over the years, and although some progress has been made, a definitive proof has yet to be found. In fact, the Goldbach conjecture is widely considered to be one of the most difficult problems in number theory, and it continues to fascinate mathematicians and inspire new research to this day.
User: If you have a number that is not prime, what does that tell you in terms of its prime factors.
ChatGPT: If a number is not prime, then it can be expressed as a product of prime factors. This is known as the Fundamental Theorem of Arithmetic, which states that every positive integer greater than 1 can be uniquely expressed as a product of prime factors, up to the order in which the factors are written.
For example, the number 12 is not prime, and it can be expressed as a product of prime factors as follows: 12 = 2 × 2 × 3. In this case, 2 and 3 are the prime factors of 12. Similarly, the number 30 can be expressed as a product of prime factors as 30 = 2 × 3 × 5, where 2, 3, and 5 are the prime factors of 30.
The prime factorization of a composite number provides information about its divisors and allows us to break down the number into simpler factors, which can be useful in a variety of mathematical applications.
User: Say you have a number that is not prime, and express the prime factors as logarithms, what does that tell you?
ChatGPT: If you have a composite number and express its prime factors as logarithms, it can give you some information about the distribution of the prime factors and the size of the number.
In particular, the prime factorization of a composite number can be expressed as the sum of the logarithms of its prime factors. For example, if we take the composite number 360, we can express its prime factorization as:
360 = 2^3 × 3^2 × 5
Taking the logarithm of both sides to the base 10, we get:
log(360) = log(2^3 × 3^2 × 5) = log(2^3) + log(3^2) + log(5)
Simplifying this expression, we get:
log(360) = 3 log(2) + 2 log(3) + log(5)
So, expressing the prime factors of 360 as logarithms tells us that the number has a relatively even distribution of prime factors, with 3 factors of 2, 2 factors of 3, and 1 factor of 5. It also tells us that...
Michael Wessel
iSax
Michał
Tauno Erik
Watch Wrestling is available to stream quickly and in great definition for free
online hd free in high quality. WWE Raw, WWE SmackDown, WWE Main Event, and WWE
NXT where you can watchwrestlling.com without any sign up or registration fast servers.
Watch Wrestling
