January 2026: Acquired a FW 13 Mainboard
01/31/2026 at 05:34 • 0 commentsIf you've made it this far, thanks for taking a look at my project. Still terribly busy with my new job, but it keeps the lights on. Despite the state of the economy and the computer parts market, the stars aligned and I have finally sourced a Framework 13 mainboard and RAM within my budget.
Still as motivated as ever, perhaps more so after having just poured a chunk of money into the aforementioned parts. X230 remains my daily driver and no new laptop to date scratches that itch for an indefinitely upgradable chassis with the classic ThinkPad-like experience.
The next objective is to pick up where I left off with the keyboard. Test it out when that's done. Then we will address the chassis.
A new cost breakdown for the build, sans mainboard/RAM/storage due to their highly variable cost:
Part Vendor Cost (USD, estimated) Aluminum Chassis* TBD 900 Kailh Choc keyswitches* eBay 50 Keycaps and stabilizers** TBD 80 Keyboard PCB* PCBWay 30 Keyboard supporting components & connectors* TBD 20 TrackPoint module* eBay 20 LCD Panel (Equivalent to first-party) eBay 70 4 expansion cards Framework 60 Webcam cable Framework 15 eDP cable Framework 9 Audio daughterboard Framework 14 61 Wh battery Framework 69 4.0 kg hinges (the custom lid is likely heavier) Framework 24 Speakers Framework 19 Speaker kill switch and Worklights* TBD 8 Webcam Framework 39 Fingerprint reader Framework 24 Antenna*** Framework 25 Fasteners* TBD 15 Various 3D-printed parts* TBD 10 Total $1501 *This estimate is for one-off production. May be lower with larger batches.
**It turns out that Kailh Choc keycaps are a very niche category already, so it might be worth investigating 3D-printed keycaps.
***May need investigating due to it no longer being sold separately and design differences of a custom aluminum lid.
Fundamental changes to the project
12/02/2024 at 01:05 • 0 commentsFramework 13 instead of Framework 16
This project will now target the Framework 13 mainboard instead of the Framework 16. Mainly due to concerns about the bulk of the final product:
- Video reviews after the its release put into perspective the size of the machine.
- It would be at least 3.5 cm thick. To see how it would unfold, I used an 3 cm-thick laptop with a similar footprint for a couple of weeks. I did not like it much.
- I sincerely apologize if this change has disappointed you.
Fully custom lower chassis
Because having to work around the existing lower chassis:- Severely limits our design choices
- Introduces an awkward midframe and its associated linkages
- And therefore would neither decrease costs or improve structural integrity significantly
First-party LCD
- The previous proposal to use an undersized LCD poses sourcing and compatibility concerns
- Further thinking revealed methods of rearranging components in the lid to keep the first-party display an option
Status update while I'm logged in
08/02/2024 at 02:33 • 0 commentsNew job, very busy. New stuff to come in a couple of months or so once I get things settled.
Estimated Bill of Materials
01/28/2024 at 20:50 • 0 commentsBe aware that putting this together, even without prototyping expenses as the "end-user", will be more expensive than buying the MacBook Pro 16. This is a project for the passionate!
Below is a rough cost estimate in the configuration that I plan on using:
Sub-Total: $2504
Base laptop
- We do not need the first-party keyboard, trackpad, or screen, but buying only the required parts from the marketplace does not save us money over the DIY edition.
- Added benefit that you can revert to the first-party parts if the mod does not work out for you.
$1399 Framework Laptop DIY Edition with Ryzen 7 7840HS $80 6x Expansion Cards $200 4TB NVME SSD (Amazon) $85 32GB DDR5 SODIMM (eBay) $60 USB-C PD Charger (Amazon) Display Assembly and Palmrest
$300 3D-printed palmrest and display bezel pieces in ABS (outsourced) $100 1920x1200 14-inch matte IPS LCD (eBay) Keyboard
$80 110-pack Kailh Choc low-profile switches (Amazon) $70 Full set of Kailh Choc keycaps (Aliexpress) $50 Keyboard PCB(s) and supporting components (PcbWay) $10 RP2040 Microcontroller (eBay) $20 TrackPoint module - We do not need the first-party keyboard, trackpad, or screen, but buying only the required parts from the marketplace does not save us money over the DIY edition.
Theoretical approach to an extended battery
11/10/2023 at 22:47 • 2 commentsI have been spoiled for choice when it comes to batteries on older ThinkPads. At present, Framework laptops have only one internal battery that is rumored to be middling in terms of capacity relative to power consumption and not swappable without tools.
Assuming no other third parties release a battery pack for the Framework 16 expansion bay in the next 5 years and the expansion bay power delivery system supports charging input, I may consider building my own based on the guide: https://www.instructables.com/Battery-Powered-Raspberry-Pi-in-Repurposed-Laptop/
Mostly just a note to myself so I don't just forget about the work of a very dedicated Raspberry Pi owner to make SMBus charging work for him. I say this because I had long thought that making my own battery pack that reports battery percentage to the OS would be unrealistic.
Preliminary Timeline
07/17/2023 at 20:29 • 1 commentI do want to have an upgrade to my aging X230 laptop ready in the next couple of years, so
- I don't anticipate this fizzling out, added that I refuse to give up the TrackPoint and classic keyboard
- I do anticipate the timeline changing depending on my available free time
Here's the timeline on my mind:
Spring 2024: I get my hands on the Framework 16 laptop
Summer 2024: Make measurements, test out parts, start playing with CAD
Fall 2024: Start running test prints and fine tune parts
Winter 2024: Put everything together, final testing and fitting, take glamour shots, polish up the write-up, and publish everything
Mid-2025: Probable actual completion date. Good thing that Framework promises to release case-compatible mainboard updates so this won't immediately become irrelevant once I finish.
Kartoffelstolz
