The HEXA printer is a 3D printer that uses six linear axes to move the head, similar to a delta printer, with six degrees of freedom to control the position and orientation of the nozzle tip.
Various benefits can be expected from posture control, such as support-less and infill-less printing, improved surface properties, and improved strength of the formed object.
In particular, support-less and infill-less printing by diagonal modeling is a very beneficial technology that reduces environmental impact.
Advantages of multi-axis printing
(1) Reduction of support infill by printing diagonally.
(2) Improved lamination strength.
(3) Realization of stacking considering the direction of load.
(4) Improvement of surface properties.
gear_geek
adamfilip
Nutty Gear Studio
