Toddler_Cyberdeck_v2.inoAdds low power and auto-power off. Requires the Low-Power library by Rocket Scream Electronicsino - 15.72 kB - 08/19/2024 at 00:05 |
Switch layout options.pptxI used powerpoint to plan the switch layout. Faster than a CAD system since accuracy was not required.presentation - 75.65 kB - 08/15/2023 at 04:03 |
Toddler_Cyberdeck_v1.inoThis is the final V1 code, as loaded into the project. This has some specific changes to fix hardware errors, so you should use the wokwi.com project as the basis for your own.ino - 10.88 kB - 08/15/2023 at 03:45 |
Josh
