Special features
- side wheel with button for cursor keys and enter (useful in the terminal)
- very easily customizable IO and back panel (because I'm someone whose projects are never really finished)
- two wifi adapters (USB and Raspberry builtin)
- two bluetooth adapters (USB and Raspberry builtin)
- zigbee adapter (to debug zigbee networks)
- internal SD or microSD memory
- three external usb ports
- external SD and microSDcard reader
- external 5 gpio connectors, 5V, 3.3V, ground (so that raspberry tinkering can be tested quickly with a breadboard)
- can be used as a full desktop
Design in general
- retro look
- sturdy
- compact
- easy assembly (without glue)
- easy access to the internal components
- customizable without having to reprint the case
- no screws visible from the outside
- dimensions 253x253x104mm
Rear panel
(can be slided into the case and is held in position by the bottom cover)
- raspberry microSD access
- "usb c" charging port
- external WiFi antenna
IO panel
- three USB Ports
- 8pin gpio (5v, 3.3v, ground, gpio's)
- RJ45 LAN
Peripherals
- trackball and mouse buttons
- knob (for cursor keys and enter)
- full mechanical keyboard
Other properties
- good raspberry cooling (so that it is not throttled)
- stereo speakers
- capacitive touch screen
- power and act LED
Painting color
- primary color: RAL1015
- Secondary Color: RAL7016
future plans
- usb micro b and a wide range charging port (5-30V with banana jack (rear panel)
- HDMI output (IO panel)
- Battery (the UPS board which can be seen in the CAD drawings turned out to be a flop (aliexpress 52pi UPS plus)
Nick Scratch
Steve Anderson
0x17
Leandra Christine
I'm just now getting around to building my Cyberdeck based off of this but the Vortex keyboard is out of stock. Any recommendations on what to use instead?
