3D-Printed Latch
08/08/2023 at 03:13 • 0 comments![]()
Kinematics & Horrific Trigonometry
08/07/2023 at 15:14 • 0 commentsWhen modelling the latch in OpenSCAD I included the kinematic model - essentially the movement of the latch is a parameter, and all parts move as if they were bolted together and to the appropriate pivot points. Why include this? The most vain reason is that it allowed me to see how the latch worked in motion - and to see if this was something that was interesting enough to spend the time and effort on. A side effect of this was creating some of the animated images you can see in other posts. A more practical reason is that it allowed me to test the model for interference - any point in the motion where one part wants to be in the same place as another part - obviously this would cause a problem.
Anyway, it's finished now, so I wanted to share a little bit of the process of creating the kinematic model. What it came down to was maths. Hideous, horrifying quantities of trigonometry. The YouTube channel ThisOldTony describes trigonometry as "shop math" - math for the machine shop - and while that's accurate, trigonometry really does feel like a blunt instrument at times. Is there a better way to do this? Probably, but I'm afraid I never learnt it...
3D Printing & Design References
08/07/2023 at 12:58 • 0 comments![]()
I've finished designing a version of the latch that can be 3D printed, which is now underway. I'm sure I'll find some tolerance that is too tight, or some part interference, but that's just the way 3D printing goes in my experience...
In the meantime I wanted to share a couple of useful resources that I found online while researching this project. First, This page has a copy of a diagram of the Apollo hatch that shows a bit of detail how the hinges attach to the capsule - something that is missing in a lot of images online: http://heroicrelics.org/info/csm/cm-hatch.html
Next, this article from the Journal of Spacecraft and Rockets titled "Review of Seal Designs on the Apollo Spacecraft" mainly focusses on the design of the hatch seals, but has some fascinating detail: https://www.researchgate.net/publication/245438272_Review_of_Seal_Designs_on_the_Apollo_Spacecraft
Lastly, this article by Lance Lininger and Kyle Gotthelf titled "Design and Test of the Orion Crew Module Side Hatch" focusses on the hatch design for the Orion spacecraft. There's a bit of comparison to the Apollo designs, but there's also a wealth of information including how the hatch lever gearbox works, and interesting problems like how the flexing of the hatch door under pressure affects the rods that open and close the latches. https://www.esmats.eu/amspapers/pastpapers/pdfs/2020/lininger.pdf
Hinges!
08/01/2023 at 12:34 • 0 comments![]()
And here's the matching hinge. The NASA design uses a bewildering 6-bar linkage, and there's still a lot of work to do on this to fine-tune the lengths and angles, but the kinematics actually work in OpenSCAD
Latches
08/01/2023 at 09:57 • 0 comments![]()
The latches used on Apollo Block 2 spacecraft are a pretty cool piece of engineering. Essentially, they're designed to lock closed in such a way that any force trying to push open the door is not transmitted beyond the latch itself - there's a handle that opens and closes the latch, but any force on the latch won't exert any force on the handle.
The Apollo hatch would use 14 of these - all attached with pushrods and bell-cranks at the corners.
I'm not sure who the credit for this design goes to - someone at NASA, Rockwell, or someone else - but there's a ton of great imagery and detail at Historic Space Systems here: https://space1.com/About_Us/In_the_Works/Apollo_Hatch_Latch/apollo_hatch_latch.html as well as this awesome paper craft version at Paper Modelers: https://www.papermodelers.com/forum/pasa-paper-aeronautical-space-administration/45348-apollo-cm-crew-hatch.html
I've modelled a version of the latch in OpenSCAD. At the moment this is mostly to work out how the kinematics operate, but this will form the basis of a 3d-printable version
Tobias
