There are many RF mixer topologies that use many different types of non-linear devices.
Basically there are two board classifications: (1) switching and (2) non-linear.
After searching the Internet I did find a few circuits with component values and local oscillator power requirements that allowed me to digitise a schematic in order to look at the simulation:
Okay it is pretty clear that it is a Class B amplifier (an important observation!).
Next lets mix in the signal:
And what did I get:
Now this is not right! Even with a uV signal?
Okay reduce the coupling capacitor:
And now it works (all that is required is a low pass filter to extract the 100 kHz signal).:
Need to look at the range of couple capacitors values that work.
The above local oscillator (LO) is 1 MHz and 2v pp and the signal is 1.1 MHz and 200 mv pp. Getting a 50% duty (i.e. Class B operation) for the mixer requires adjustment of the LO amplitude or the bias resistors.
Conclusion
Well I am happy I now know how this mixer works. It is a switching mixer) configured as a Class B amplifier. It is now easy for me to design and to tweak.
Recovering Audio
The modulated RF is 2 mv pp and the recovered audio is 1 mv pp. The line thickness is due to left over RF. Pretty happy with that.
Port Isolation
How much is the LO isolated from the input? Practically nothing gets through:
what you use to simulate this mixer ?
i need something similar but for FM?
