Doing some test, I found that at least one channel seamed not to work (Sensor 2, blue). Also by moving the whole know in the earth magnetic field, the signal did not
Then I printed a fast fixtured I had ten to tighten with tape. The fixture holds a 60m diameter 10mm high metal block. Fixture was not too bad, maybe a bit to stiff. I will have to design a better housing and then test again.
